tgm Posted August 26, 2004 Share Posted August 26, 2004 Last nite after I posted the Revision Cloud crash topic I noticed that my Object Info palette would not work. Well it still does not work this morning. I opened up a new drawibg and put a square on it and hit Ctrl-I. The palette bar appears but will not drop down or open. If I double click on the bar it will expand across the whole screen at the drawing bottom and have the info there. As soon as I try to move it to resize and dock it, it quits working. Anyone from VW have any ideas??? Thanks, Tom Marino Quote Link to comment
Guest Posted August 26, 2004 Share Posted August 26, 2004 Tom, Is the problem that the palette doesn't work at all - you can't change values of selected objects - -- or is the problem that you can't get to anything in the OIP to change it? Quote Link to comment
Guest Posted August 27, 2004 Share Posted August 27, 2004 Next time it happens, while the palete is docked - hold down the control key and pull the palette out of being docked. Then, using the resize cursor in the lower right corner, decrease or increase the size of the palette. Quote Link to comment
tgm Posted August 28, 2004 Author Share Posted August 28, 2004 Katie, As stated above the palette bar will not drop down or open. I have since re-installed VW and the 11.0.1 update and it appears to be OK now. Tom Marino Quote Link to comment
