Peter Vandewalle 0 Posted Monday at 07:45 AM Is there a way to get the origin of the model in a section viewport? Since the Elevation Benchmark Tool is able to create a value based on the Z-origin, I suppose it should be possible. I just can't seem to figure out how... Share this post Link to post
Boh 16 Posted Monday at 09:08 AM What about placing a locus on the user origin of a design layer and cutting and pasting it in place in a section viewport annotation? in theory it should past at the origin point of the section view. There is also a setting on the elevation benchmark tool that will reference the z height on the section (can't remember what it is called exactly). Share this post Link to post
Peter Vandewalle 0 Posted Tuesday at 07:47 PM (edited) Hi Boh Doesn't work. Copy-pasting a 3D locus into a viewport annotation isn't possible. Copy-pasting a 2D locus will paste it onto the origin of the sheet layer inside the annotations. No luck so far... Edited Tuesday at 07:47 PM by Peter Vandewalle Share this post Link to post
Boh 16 Posted Wednesday at 07:18 AM i don't think there is an origin point as such in section and elevation viewports. im interested to know why you want to know that? If you use the benchmark tool with "Y value relative to reference elevation" you can at least work out the z=0 height. But it looks like you have figured that out. Share this post Link to post
Peter Vandewalle 0 Posted Wednesday at 08:52 AM I'm trying to create a kind of benchmark that could also modify the Story levels. I can do that, but then the section viewport needs to be positioned so that the origin of the model in the viewport matches the origin of the sheet layer. I'm trying to modify it so that it would work also when, the section viewport is positioned elsewhere on the sheet layer. I have been thinking about the elevation benchmark tool, but I can't read the indicated height value from the PIO object, there's no parameter for that... Share this post Link to post
