The text in the section marker tool and the mark itself are right now treated as two sperate movable entities which drive me nuts. To adjust the marker - you have to move the text first (because it is on top) - then select the line - select the control point and then snap that to the moved text. Essentially increasing the amount of work by 100% to modify section marker.
Whoever wants the text not in the marker? I tried to think of a time or instance where I would want the 3/A-201 text in some other place other than inside the mark. The only thing I could think of if it was too big to fit.
So - if this is really a feature that people need - maybe have a "Fixed Text" check both that will make the text and the mark move together.
Tom Klaber
5 answers to this question
