hong Posted August 25, 2004 Share Posted August 25, 2004 Is there a way to make this gray darker? 'Grey other layers' is a good option to make contrast between, let's say', existing to new construction. However when to print, grayed background seems to be too light and I am wondering if there is a setting to make it darker without using layer color assigned. If I assign a layer color to darker gray in document setting, it doesn't change hatches. Quote Link to comment
Guest Posted August 25, 2004 Share Posted August 25, 2004 Unfortunately, there is no way to change the gray hue used for grayed layers and classes. I've noticed the gray changes slightly from printer to printer. You may be able to increase the depth of the gray by increasing the dpi from 300 to 600. [ 08-25-2004, 11:44 AM: Message edited by: Katie ] Quote Link to comment
