BG Posted August 24, 2004 Share Posted August 24, 2004 2 messages while printing drawings (8 different sheets in the same file), using FILE, PRINT first message ?vectorworks has detected a condition of instability?. Save and quit vectorworks? second message a minute later ?Vectorworks will shortly be unable to continue functioning. Please save your work and quit immediately to avoid loss of work? Any ideas how to prevent these messages happening? VWA11.0.1 G4MacOS10.2.6 768 MB RAM Quote Link to comment
Ray Libby Posted August 24, 2004 Share Posted August 24, 2004 Do a search on "Please save your work and quit immediately to avoid loss of work". Search button is in the upper right hand corner. Quote Link to comment
Guest Posted August 24, 2004 Share Posted August 24, 2004 YOu should update to OS 10.2.8 to avoid a printer instability issue. Following the update, run Disk Utility to verify and repair disk permissions. Meanwhile, if there is a file that is corrupted because of this, please email it to me and I'll have the file diagnosed. Quote Link to comment
BG Posted August 26, 2004 Author Share Posted August 26, 2004 Hi Katie Updated the OS and did the disk repairs etc but still getting the same messages. This is happening on multiple files. Any other suggestions? Thanks BG Quote Link to comment
BG Posted August 26, 2004 Author Share Posted August 26, 2004 Ray "Do a search on "Please save your work and quit immediately to avoid loss of work". Search button is in the upper right hand corner." Is this a search within Vectorworks? BG Quote Link to comment
Guest Posted August 26, 2004 Share Posted August 26, 2004 Are you positive you are using VW 11? Quote Link to comment
