Mikedk64 Posted April 11, 2018 Share Posted April 11, 2018 Hi, I have a few question regarding the parameters in my custom tittle block - Is it possible to delete standard parameter that I don’t want (I can with my own parameters) - Is it possible to rename standard parameter (I can with my own parameters) - Is it possible to lock the parameters that automatic is getting its data elsewhere Here is a small screen dumb of some of the parameters Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted April 11, 2018 Vectorworks, Inc Employee Share Posted April 11, 2018 Hello Mike, 1 hour ago, Mikedk64 said: - Is it possible to delete standard parameter that I don’t want (I can with my own parameters) - No 1 hour ago, Mikedk64 said: - Is it possible to rename standard parameter (I can with my own parameters) - No, standard parameters are only being localized and not renamed 1 hour ago, Mikedk64 said: - Is it possible to lock the parameters that automatic is getting its data elsewhere - Could you be a bit more specific here? Do you mean that you do not want Sheet Number/Title to be changed for sheet layer, when changed in the Title Block? Finally, the image you have attached is broken, I cannot open it. Best Regards, Nikolay Zhelyazkov Quote Link to comment
Mikedk64 Posted April 12, 2018 Author Share Posted April 12, 2018 I figured something out, thanks Quote Link to comment
