bc Posted April 10, 2018 Share Posted April 10, 2018 (edited) Hello all, I know VERY little about Schedules in VW, so bear with please. I have my window ID set to on schedule and I have created a Window Schedule below. Two Questions: 1. How can I make the green highlighted row disappear? I know it is full of data base stuff and I need it to auto fill the schedule. I just don't want to see it. EDIT: I FIGURED THIS ONE OUT. 2. How can I make the column SILL (which doesn't have data base stuff in it) show the window sill lengths? Or at least have a text box in each cell I can type the info into like the NOTES column. Thanks bc Edited April 10, 2018 by bc Quote Link to comment
michaelk Posted April 10, 2018 Share Posted April 10, 2018 1. View>Uncheck Database Headers. (The View menu in the worksheet, not the main program View menu) 2. Before you do #1, put this in the cell 3F: =('Window'.'SillExt'*2)+'Window'.'OverallWidth' This will read the sill extension from the window settings, double it and add the window width. Quote Link to comment
michaelk Posted April 10, 2018 Share Posted April 10, 2018 PS. If you want to put any other data use the call ='Window'.'UserFld1' ... ='Window'.'UserFld10' There are 10 user fields in windows that you can use for any data you want. You can also see them in settings. Select a window > OIP Settings > Data. At the bottom of the list are 10 user fields. Quote Link to comment
bc Posted April 10, 2018 Author Share Posted April 10, 2018 OK thank you Michael Quote Link to comment
bc Posted April 10, 2018 Author Share Posted April 10, 2018 OK now I can't figure out what a "call" is or how to switch the results in column SILLS to Ft-Inches (like HEIGHT AND WIDTH) instead of the reported decimal ft. Quote Link to comment
michaelk Posted April 10, 2018 Share Posted April 10, 2018 A "call" is what you type into that database header row. It always starts with an equal sign and then a function or field in a record. Like =WIDTH or ='record'.'field' It's probably has a real name. "Call" is what I've heard it called. To switch the format of the dimension right click on one of the cells in the Sills column with a decimal value, choose Format Cells > Number Tab > Check Dimension. All the cells in that column will use the default document dimension format. Quote Link to comment
bc Posted April 10, 2018 Author Share Posted April 10, 2018 THANKS! I THINK I'M THERE!.....UNTIL. Quote Link to comment
Pat Stanford Posted April 10, 2018 Share Posted April 10, 2018 I would use the term Function instead of Call. In most programming languages you "Call" a function when you want to use it, so the terms have kind of overlapped. While the =Record.Field is kind of a special case, it is very similar to all of the other functions that you can put into a cell using the Insert:Function worksheet menu. Quote Link to comment
michaelk Posted April 10, 2018 Share Posted April 10, 2018 It is confusing. Now that object attributes (=ALL - =WST) are lumped into the database column header pulldown with the functions (Arc Cosine - Z Coordinate) it makes sense to call all of them functions. But I still think of retrieving data from a field in a record as a database call". Quote Link to comment
bc Posted April 10, 2018 Author Share Posted April 10, 2018 95% of it is greek to me. And the VW help dosen't really help much. I guess the assumption is that everybody knows all these functions. Quote Link to comment
Pat Stanford Posted April 10, 2018 Share Posted April 10, 2018 Hint, Hint. If you want to know more about Worksheets, you might want to spend some time I'm Phoenix in November. I hear there are going to be a couple of good dudes there then. Quote Link to comment
bc Posted April 10, 2018 Author Share Posted April 10, 2018 I would love to but...it doesn't look like it's in the cards. Quote Link to comment
