Ricardo Fernandes Posted April 10, 2018 Share Posted April 10, 2018 Help me!!!! How I can change the lineweight in viewports. After publish it's look like this... 1 Quote Link to comment
RGyori Posted April 10, 2018 Share Posted April 10, 2018 With the viewport selected > OIP > Advanced Properties (at the very bottom) > Line Weight Scale (at the very top). Default is "1" so to reduce the line weight in the Viewport change it, say 0.5 for 1/2 the line weight and so on... Bob 3 Quote Link to comment
EAlexander Posted April 10, 2018 Share Posted April 10, 2018 (edited) Also - check your Sheet layer DPI - this can affect line weight as well. By default - each sheet is set to 72 DPI - so upping it to 200 or 300 will make for finer lines in Open GL and section viewports. Just right click on the sheet layer name in the navigation palette and choose edit. And - by default - the Section Style class that gets applied to sections cuts has a default line weight of 1.02 which is like drafting with a crayon - so editing that class can help for sections. e. Edited April 10, 2018 by EAlexander 2 Quote Link to comment
