export web view w clip cube issues.
So tried to export a couple of files with the clip cube turned on as advertised. I get windows outside of the clip cube showing up along with triangulation of the cut plan to adjacent windows instead of a clean cut. The windows are symbols both inside and outside of the clip cube. Cuts thru walls are not along the clipping plane. In sum, unless I'm missing something, this really doesn't work.
Hello @jnr,
Thanks for posting about the problem that you are encountering with Web view! If you could send me the .vwx file to inikolova@vectorworks.net, and a screenshot of the Web view export options that you are using as well as a screenshot of the result you are seeing, it would really help us troubleshoot the issue.
Thank you!
Regards,
Iskra Nikolova
