Grethe Connerth
Hidden Line Rendering with Objects have no Fill when Stacking Viewports
Dear VW Lovers,
I am creating a Viewport with Hidden Line RW Style.
Unfortunately the process of rendering is not possible, meaning it not only renders indefinitely but also the VW program becomes none responsive. This probably due to a lot of detail in the drawing.
As a result I have to 'Force Quit' the program and start again.
After many times of trying I am now working around the issue like this:
Viewport on-top of Viewport
- splitting the drawing into multiple Viewports with different Design Layers visible
- thereafter I overlay one Viewport on-top of the other
--> Problem
Any objects in a Viewport are not filled.  --> Which results that you can see through all the objects on any VP.
 I would like to be able to create a VP that 'closes' the objects and nit the whole VP. Like when you give an object a fill through the Attributes.
Only when I give the VP a fill through the Attributes palette the whole VP becomes filled and not only the objects.
I have attached a screenshot of the individual Viewports and the one on the right hand side bottom holds the sandwiched Viewports.
Here it shows that all objects have no fill.
I would be grateful for any input and work around.
Cheers,
Grethe
The only workaround I know of would be to give the viewports a background render of either OpenGL (lines and colours turned off) or Custom Renderworks and a foreground render of Hidden Line. I've attached an example file using OpenGL as the background render.
Your model doesn't look that complex so I'd be curious why it wouldn't render altogether. Perhaps you have a corrupt object.
Kevin
5ac196e88b768_ScreenShot2018-04-01at7_35_01PM.thumb.png.272bbf69cb70f9a6d7f362ba924f7948.png
Overlay Example.vwx
Edited by Kevin McAllister
Clarity
Hi Kevin,
thank you for your fast reply and also the VW Test file which was very helpful.
I tried your suggestions and it took a few test, I had to turn off all the Lights and also combine the Bubble Panel Walls VP with the stage VP as it didn't overlay correctly with all the walls and so forth.
--> new VPs attached
It looks good and clean, even though I was aiming for a black & white render only without the Greys from OpenGL.
Reason being as all my other explanatory Renderings are Hidden Line only.
Yes you have a very good point.
I was wondering this also, especially as I have other VPs with Hidden Line Renderings and they seem to be working even with all the objects in there.
See screenshot of a different scene / VP attached --> Hidden Line with one single Viewport
Maybe I have to throw away this particular VP, re-create this View into a new VP and then render it all in one with Hidden Line.
Cheers,
Grethe
I might have a potential solution for this. Select all of the stacked viewports with the OpenGL background and click on the Lighting Options button in the OIP. Under ambient info turn up the brightness to 100%. In my test file it washes out all of the shadows. You wouldn't normally want this but because you're only using the OpenGL portion as fill it doesn't really matter.
Kevin
  • Like 3
Hi Kevin,
Yes it did wash out all greys!
And it shows some shadowing in the corners, which I can test and play around in the Lighting settings.
But you know what? I love it !!!
It looks even better than the plain Hidden Line RW Style.
I rendered the Viewport showing the side view also and it did a great job.
Perfect ! Legend !
Thank you Kevin for this simple work around !!!
Grethe
  • Like 3
Kevin
This is the technique we use to get hidden line as well !
Kevin beat me to it :)
  • Like 3
Hey Guys,
sorry to dig up a year old thread again, but how did you get the pink glow to come through in the first set of images?
It's the effect i'm after 99% of the time and would love to not have to try and mess around focusing lights if possible.
Cheers,
Jack
