Join a line with an arc
This is something I can never make work.
I want to duplicate along a path.
The path contains an arc. I can't freehand draw this because it comes out all wavy.
So I draw a straight line, an arc, and another straight line, but you can't duplicate along multiple lines.
If I try to join a line, and an arc together they form a 90­° L.
If I decompose the arc to lines they won't join.
see attached super simple example.
This can't be this hard.
arc.vwx
The Join tool will joining or trim two lines together to make a line or two lines. If you compose the lines together they become a polyline which may not be what some users would want. In all honesty the differences are subtle but I can see a use for some of the functions. Take a look at the help files to see what I mean http://app-help.vectorworks.net/2018/eng/index.htm#t=VW2018_Guide%2FObjects_edit2%2FJoining_Objects.htm&rhsearch=join&rhhlterm=join&rhsyns=
It feels like a command that has been superseded by other more elaborate tools. I guess some users would miss it so maybe Vectorworks they have kept it just in case..... ?
