Unlink text object from record
Try this script. If this is an acceptable workflow, it can be edited to keep the text that was in place prior to the unlink.
Procedure UnlinkTTR;
{March 29, 2018}
{© 2018 Patrick Stanford pat@coviana.com}
{Licensed under the GNU Lesser General Public License}
{Edit a Symbol, select any text you want to unlink from }
{a Linked Text to Record and run this script.}
{The text will revert to the original default text but the}
{text location will be the same.}
Var    H1    :Handle;
Procedure Execute(H1:Handle);
Begin
    SetObjectVariableBoolean(H1, 686, True);
End;
Begin
    ForEachObject(Execute,((INSYMBOL & (VSEL=TRUE) & (T=TEXT))));
End;
Run(UnlinkTTR);
{March 29, 2018}
Var	H1	:Handle;
Begin
End;
Begin
End;
Run(UnlinkTTR);
  • Like 3
  • 2 months later...
