cberg Posted March 26, 2018 Share Posted March 26, 2018 Simple question. Is there a way to convert walls to generic solids? Or generic solids to walls? What about converting floors to generic solids, or generic solids to floors? Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted March 26, 2018 Vectorworks, Inc Employee Share Posted March 26, 2018 Honestly, the fastest way I have found to do this is to export to STL, re-import, then Modify > Convert to Generic Solid. The only reason I don't just recommend using Modify > Convert > Convert to Mesh and then using Modify > Convert > Convert to Generic solid is because some objects won't let you convert to mesh directly, but nearly any 3D object can be exported to STL in a single step. Quote Link to comment
cberg Posted March 26, 2018 Author Share Posted March 26, 2018 Wow. Thanks Jim! This should be added to the functionality of the program! It would really help workflows. In the early stages of design, one doesn't necessarily care about the type of object and it is easier to model in 3D using generic solids, extrudes, etc. Later in the design, there should be some way to retain this information and translate it to smarter sorts of objects. Appreciate your help! Quote Link to comment
zoomer Posted March 27, 2018 Share Posted March 27, 2018 (edited) 18 hours ago, JimW said: Honestly, the fastest way I have found to do this is to export to STL That's a cool idea ! And very important for me as Walls, my main type of geometry in general, don't export as Solids into DWG but Surfaces only. Which I had to stitch together again elsewhere. And sometimes I would even like to convert some selected Walls to Solids for Vectorworks usage. 18 hours ago, JimW said: re-import, then Modify > Convert to Generic Solid. The only reason I don't just recommend using Modify > Convert > Convert to Mesh and then using Modify > Convert > Convert to Generic solid Is this Convert a "Mesh" to Generic Solid function new ? (Coming along with SubD to Solid conversion ?) The only way I knew so far to force a Mesh back to a Generic Solid was to try if PushPull works in second mode .... Edited March 27, 2018 by zoomer 1 Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted March 27, 2018 Vectorworks, Inc Employee Share Posted March 27, 2018 6 minutes ago, zoomer said: Is this Convert a "Mesh" to Generic Solid function new ? (Coming along with SubD to Solid conversion ?) I know it was enhanced recently along with that tool. I am fairly sure it existed before but it was way more particular about what objects it would let you convert and these days it's more reliable, however the shape you're converting still has to be a watertight/manifold solid, no 0 thickness faces are permitted if I recall correctly. Quote Link to comment
cberg Posted March 27, 2018 Author Share Posted March 27, 2018 I convert meshes to generic solids all the time. I didn't realize it was an improved feature. Quote Link to comment
zoomer Posted March 27, 2018 Share Posted March 27, 2018 (edited) 1 hour ago, JimW said: however the shape you're converting still has to be a watertight/manifold solid, no 0 thickness faces are permitted if I recall correctly. OK, so for no cleanup of the furniture libraries 1 hour ago, cberg said: I convert meshes to generic solids all the time. I didn't realize it was an improved feature. I tried this in the past and it was rejected. (Tried that for Walls to at one point of course) So I tried everything to find a workaround until I came to the PushPull trick. Another option my be the ACAD way : - exploding the Mesh - convert 3D Polys to Nurbs - Modify>3D Power Pack>Stitching Surfaces Edit : No, does not works as I expected .... I tried now also Convert SubD - Crease All - Convert to Generic Solid But that will keep SubD's tessellation of Faces and we have no Simplify Solid command. (Redundant "Co-Edges") Could be an option for more complex Mesh geometries though. (And for me VW crashes when 1 hour ago, JimW said: I know it was enhanced recently along with that tool. I tried and it works Why wasn't that mentioned along Shiny New Features at release and got its own Feature Video ? For me that is a very important feature ! Edited March 27, 2018 by zoomer 1 Quote Link to comment
markdd Posted March 28, 2018 Share Posted March 28, 2018 If its just the wall you want without the doors and windows (the apertures are retained) then Convert to Nurbs and then Add solids on Nurbs Surfaces in the resulting group. That will give you a solid addition that you can convert into a Generic Solid. 1 Quote Link to comment
