Hello Community!
This Thursday, October 21st, from 6 pm to 7 pm EDT, we will be performing an update on the Vectorworks Community Board. During this time, the site will be unavailable.
  • 8
Multiple Fillet Selection
Andy Broomell
When you select multiple 3D Fillet objects and they have the same fillet radius, the OIP should display that radius so you can change multiple fillets at once. Currently that field disappears, so you have to select each Fillet individually and change the radii manually. (In fact, the OIP only says "2 CSG Solids" and that's it.) If you have 40 fillets to change this takes way longer than it should.
5ab91baa9d82b_ScreenShot2018-03-26at9_07_56AM.thumb.png.036e42cd6bea59ed9a15901c126f0dc6.png
5ab91ba6985a9_ScreenShot2018-03-26at9_08_03AM.thumb.png.d049097887a430e3ea1810ba5bd104d4.png
Same goes for 3D Chamfers.
If you select multiple 3D Fillets with different radii, the Radius field should still display in the OIP as blank (just like if you selected Rectangles of different widths it just shows the width field as blank); then if you were to type in a new number into the blank field it would make all the selected objects have the same radius.
2 answers to this question
