We have two people using PS via Google Drive. We are fairly familiar with it and have had some success elsewhere so this might be Google Drive not playing well.
The project was set up with both as admins. I opened it and did my work and then SACCAR. The other subsequently opens and makes some changes and SACCAR.
When I open now, after the check out object/layer dialog I get the following message:
When I select no, I can't work on it. When I select yes, I still can't work on it and the file seems to revert to read only.
We have never seen this. We don't know how to "Reset the Project File". What does that mean. Recreate it? I mean, when you dbl-click it thinks you want to work.
So how can I fix this and move on and prevent this from happening? Neither of us "manually replaced or made copies" of the file. Or is it Google Drive doing that behind our backs?
bc
Any ideas? Thanks
bc
4 answers to this question
