quinncp Posted March 22, 2018 Share Posted March 22, 2018 Hello I am trying to create a corner window, I have made the element on the horizontal a window with corner window element so it snapped to the corner. The window on the vertical is a seperate element (the same window type with the corner element on) Is there a way to join these together? I have an awkward corner piece of wall sitting in the middle? Or I am approaching the window in the wrong way? Thanks for any help Quote Link to comment
Diego - Resuelvector Posted March 22, 2018 Share Posted March 22, 2018 When this happens is usually the orientation of the window in the wall or the orientation of the wall, first try to Flip the window on the wall using the Flip button in the OIP Quote Link to comment
Gadzooks Posted March 23, 2018 Share Posted March 23, 2018 (edited) 19 hours ago, quinncp said: Or I am approaching the window in the wrong way? Have you 'told' VW that you want a corner configuration? Seems like you have only chosen 'corner' for the horizontal element. Also - although you say (the vertical one) is the same as the 'horizontal' window - it appears to be different in top/plan. Choose the correct configuration for each of the windows for them to join successfully. BTW - the walls the windows are in need to be joined, or the windows will not 'see' the corner. That is unless you are creating a full height glazed corner detail (no wall parts) - I can't make that out from your plan only image. Hope that helps, but come back at me if I've not understood. Edited March 23, 2018 by Gadzooks Quote Link to comment
