dwg reference file
Is there a way to identify a class used in a referenced dwg file? I used to import dwg files into a separate file, select the classes that I wanted and then import it into a new vw file as a referenced file. This time, I've importing the dwg into a vw file as a referenced file. There are over 100 classes with the many consultants involved. I use Landmark 2018 on a Mac High Sierra.
Thank you! Terri
