I would like to request that a feature I used quite often in v2017 be added back to v2018.
This feature allows you to change the "layer" assignment of an object that is grouped with others.
This feature was added to v2017 and I found it a very valuable and time saving item that I used almost daily.
I will have several items grouped together, and when I double click on that group to edit the contents, having the ability to remove an item from the group and assign it to a different layer was a huge benefit for my workflow. Of course this object would then not be part of that group any longer, but retain it's position on another layer. For me, that other layer is typically one I call "not used", a layer for items I may need again while working.
Since this has been lost in 2018, I now have to copy the item, delete it from my group, then change layers, and then paste it. This removes me from my workflow that I enjoyed so much in 2017. Please, please, add this feature back to 2018...
dbrumbach
db
3 answers to this question
