JHEarcht Posted August 12, 2004 Share Posted August 12, 2004 In VW11.0 on Windows XP, I exported to DWG from Viewports for the first time. Several problems were immediately apparent. Line weights from 1mm to 40mm all export as 1mm. Hatches were too small and looked black. Patterns look black. Dimensions with white background show as black boxes. And most important to the engineers: the ViewPort doesn't export Classes as ACAD Layers. Non-Sheet-Layer Views do export Classes, but all other problems are the same. I have always had some minor problems with DWG exports, but VW11 is the worst so far. Is this a known glitch, or is it just me? Any suggestions? Quote Link to comment
Guest Posted August 12, 2004 Share Posted August 12, 2004 If you email the file to me, I'll take a look at the file and determine the problem. Quote Link to comment
