Ride Posted March 21, 2018 Share Posted March 21, 2018 Is it possible to create a hatch pattern that has an alternating fill colour? See attached. Seems this should be simple, but I can't get anything to work. Thoughts? Quote Link to comment
TKA Posted March 22, 2018 Share Posted March 22, 2018 hatch requires a bit of work, depending on the complexity of what you are looking for you might try "Tile" - it's simple and intuitive to set up Quote Link to comment
Pat Stanford Posted March 22, 2018 Share Posted March 22, 2018 I don't think you can use a fill in a Hatch. By definition it is a collection of lines. I often receive DXF/DWG files and anything that is filled is actually a collection of very closely spaced lines. If you don't need the lines to be too thick, could you just use very thick lines? I think VW will let you go up to 6.48mm in thickness (about 1/4 inch). Or use multiple 6.48mm lines next to each other to get the required thickness. Quote Link to comment
Peter Neufeld Posted March 22, 2018 Share Posted March 22, 2018 Hatches can have a background colour but it is only one. As TKA says Tiles are the way to go. Cheers, Peter Quote Link to comment
Ride Posted March 22, 2018 Author Share Posted March 22, 2018 Thanks for the replies....I'll give Tiles a go. Quote Link to comment
