roza Posted March 19, 2018 Share Posted March 19, 2018 I need help as a beginner. I couldn't figure out how to create a flat roof. To create a roof: - I draw a polyene around the wall - AEC create roof - changing the roof slope & eave/gable Then I change the slope to 0 - says "Roof pitch is not valid" Quote Link to comment
CipesDesign Posted March 19, 2018 Share Posted March 19, 2018 Many ways to do this. And no roof is actually totally flat. 1) try giving slope a small value (1/4" per foot, eg); 2) Use a Roof Face instead of a Roof; 3) If you really want it totally flat, try using a Floor Object; 4) You can use a simple extrude (but a Floor is better, with more control over textures and graphics). 1 Quote Link to comment
roza Posted March 19, 2018 Author Share Posted March 19, 2018 I am not able to give slope value as inches but degree... Is there any way to change degree to inches? I do a mat to figure out slope in inches... Quote Link to comment
CipesDesign Posted March 19, 2018 Share Posted March 19, 2018 In the Create Roof dialog, you can enter a pitch (slope) value in the following format: .25:1 (eg). See attached 1 Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted March 20, 2018 Vectorworks, Inc Employee Share Posted March 20, 2018 Slab objects are also good for creating flat roofs. The Slab Drainage feature allows drains to be placed and will create low pitched slopes to them: Quote Link to comment
tdmaine Posted October 2, 2022 Share Posted October 2, 2022 (edited) On 3/20/2018 at 8:59 AM, Matt Panzer said: Slab objects are also good for creating flat roofs. The Slab Drainage feature allows drains to be placed and will create low pitched slopes to them: Hi is it possible to output a tapered insulation plan to give to a vendor from the data computed and drawn by this tool? Ok I copied the roof and deleted everything but the insulation and now I can manually trim the solid in 4x8 sections. Is there an automated way to do this? Thanks Edited October 2, 2022 by tdmaine Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted October 3, 2022 Vectorworks, Inc Employee Share Posted October 3, 2022 19 hours ago, tdmaine said: Hi is it possible to output a tapered insulation plan to give to a vendor from the data computed and drawn by this tool? Ok I copied the roof and deleted everything but the insulation and now I can manually trim the solid in 4x8 sections. Is there an automated way to do this? Thanks There's no built in way to do this in Vectorworks but it does sound like something that might be possible via scripts or Marionette. 1 Quote Link to comment
tdmaine Posted October 3, 2022 Share Posted October 3, 2022 9 minutes ago, Matt Panzer said: There's no built in way to do this in Vectorworks but it does sound like something that might be possible via scripts or Marionette. Thanks! Also there is no way to add varying slopes. If you google "roof crickets". you can see the function. Basically pitched flat roofs often have pitched smaller pie shaped elements at much higher grades to direct the water. I realize it's not the most important update but it would add functionality and realism . Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted October 3, 2022 Vectorworks, Inc Employee Share Posted October 3, 2022 2 hours ago, tdmaine said: Thanks! Also there is no way to add varying slopes. If you google "roof crickets". you can see the function. Basically pitched flat roofs often have pitched smaller pie shaped elements at much higher grades to direct the water. I realize it's not the most important update but it would add functionality and realism . I absolutely agree that we need additional control for things like crickets. I do have a request entered for this (VE-96379), I'll add a link to your comment. Thanks! 1 Quote Link to comment
