Macabuser Posted August 10, 2004 Share Posted August 10, 2004 How do you flip a texture horizontally/vertically? Quote Link to comment
Guest Posted August 10, 2004 Share Posted August 10, 2004 In VW 11, select the object with the texture and use the rotate slider to slide it 90degrees, or in mapping you can change the rotation. Quote Link to comment
Macabuser Posted August 10, 2004 Author Share Posted August 10, 2004 Katie, there is no mapping button in the object info window when i select an object...i also made sure that i wasn't selecting multiple objects while i was doing this.... also, i can't download VW 11...i am having problems with that....is there a rotate slider in VW 10.5.1? Geraldine Quote Link to comment
Guest Posted August 10, 2004 Share Posted August 10, 2004 In VW 10 - click on the Texture tab of the OIP (with the object that has the texture assigned to it). CLick on the Mapping button. There is a "Rotation" input box where you can enter the rotation value of the texture. Quote Link to comment
