Mirror / copy tools, braceworks load ID
I often have a setup that will be quite the same on the other side of the centre point. Therefore I often want to use the mirror or copy tool.
I cant say that this always happens but I often have a problem with objects that have been "mirror/copied" do not have a new Load ID. It still keep the same load ID as the symbol that it was "mirrored / copy" from.
Is it a fix for this?
I have attached a picture that shows an example of what I mean. At this project, it is a 360 degrees screen, and when I have drawn all of the projection of the one side it would been nice to mirror it to the other side. When I do the Mirror function I need to adjust all of the "load ID" on the items I mirrored.
Yes, it is not a very big issue, but it takes a bit of time to do that to very time you mirror or copy symbols that need to be a part of the braceworks calculation.
  • 2 weeks later...
