tgm Posted August 10, 2004 Share Posted August 10, 2004 Is anyone besides me having a problem maintaining the default printer settings in VW11?? I am running Windows XP and an Epson C82 printer is labeled as my default. When I go to 'Print' and the dialog box pops up the C82 may or may not show as default. I keep having to go back and chage it in the dialog box, and yes I have checked my settings in the control panel and the C82 is always checked and labeled as my default. VW is the only program I am using that this happens. I previously posted this same problem and have never got a satisfactory answer so I have been keeping an eye on it and it is 'flakey'. Am I the only with the problem or I am I the only one it bothers?? Tom Marino Quote Link to comment
Guest Posted August 10, 2004 Share Posted August 10, 2004 When you notice the printer has changed, is it set to the c82 at the start of the VW session and at some point durring the session the printer has changed? Quote Link to comment
tgm Posted August 11, 2004 Author Share Posted August 11, 2004 Katie, Just yesterday I played with the default printer thing and the printer would change at will during the session. I opened up one drawing and the C84 would pop up as a default. I would reset it to the C82 in the VW Print Dialog box and print. I would have another drawing open later and the printer would change again. I can find no rhyme or reason. Even on the items I print with the C82 when I go back to print in the same session, the printer is changing. Each time this happens I go back to my system and check the default and it has always remained correct. This does not always happen each time I print. Sometimes it remains OK. Thanks, Tom Quote Link to comment
