ID Tags Oriented Wrong in Plan Drawings
What version of Vectorworks is this?
Under File > Document Settings > Document Preferences > Display, is Adjust Flipped Text checked? If you change the state of this checkbox, what happens to the ID labels?
When you say they are uneditable, are you even unable to select them? or do they select but not allow changes?
If by not editable you mean you can't see the blue handles to move the ID Tags, then make the selection tool active and make sure you are not in the first mode:  "Disabled Interactive Scaling Mode".  (The U key is the short cut that changes modes)
If you see the handles but are unable to select and move them, make sure your class options are set to Show/Snap/Modify others.
If you can see the handles, your class options are set correctly but you still can't select them:  Restart VW.
