- 5
Keep interior Elevation viewports associated with markers when moving between sheets
Asked by
nrkuhl
Asked by
nrkuhl
7150 Riverwood Drive, Columbia, Maryland 21046, USA | Contact Us: 410-290-5114
© 2018 Vectorworks, Inc. All Rights Reserved. Vectorworks, Inc. is part of the Nemetschek Group.
It would be very helpful if there were some solution to interior elevation viewports dis-associating with their markers when copying to different sheet layers. It would be fine if the move had to be accomplished by going to the elevation marker itself and specifying a new sheet layer, as long as all viewport annotation items are retained.
As it is, if I want to change the sheet layer for an interior elevation VP, I need to create a new marker pointing to the desired sheet, and then copy all annotation layer items and any crops to the new viewport, which is irritating and time consuming.
It's pretty common that we end up needing to reorganize our elevation sheets as we move through the phases, usually as new elevations become important due to finish choices.
