2 minutes ago, fabrica said:
this one in option menu ?
1017946749_Screenshot2019-06-18at15_16_10.thumb.png.10f522dae44d84d9213e3d0016336842.png
 Yes indeed, explanation in help is a bit cryptic in my opinion (but English is not my native langue)
Regarding full screen preview (from a reference guide I wrote for a class that I teach):
When this checkbox is enabled, the entire render will start coming into view at once, starting blurry at first then improving with subsequent passes. This function allows you to more quickly get a general sense of what the rendering will look like, so you can make judgments sooner. Conversely, when this is unchecked the viewport renders small squares starting at the center of the image and working outwards, and each square is the final state of the render. It is personal preference whether to utilize this function, but it should only be used for test renders and not final renders, because even though you can see an overall low-quality image sooner, it actually takes slightly longer to finalize the rendering process compared to if the function were turned off. Therefore it’s useful only if you’re actively “watching” the render happen.
Edited by Andy Broomell
When this checkbox is enabled, the entire render will start coming into view at once, starting blurry at first then improving with subsequent passes. This function allows you to more quickly get a general sense of what the rendering will look like, so you can make judgments sooner. Conversely, when this is unchecked the viewport renders small squares starting at the center of the image and working outwards, but each square is the final state of the render. It is personal preference whether to utilize this function, but it should only be used for test renders and not final renders, because even though you can see an overall low-quality image sooner, it actually takes slightly longer to finalize the rendering process compared to if the function were turned off. Therefore it’s useful only if you’re actively “watching” the render happen.
Ahhhh, can we please have this text in the help file of Vectorworks 😉 @Luis M Ruiz 🙂
In C4D this is the progressive mode I think.
Edited by Bas Vellekoop
Yes - you are talking about Progressive rendering as opposed to Bucket rendering.
In bucket rendering - the image is divided into squares and each processor core takes a bucket - renders it and then moves onto the next unrendered bucket.
Progressive rendering refines the whole image in passes.
Edited by EAlexander
Done! You'll see this in the next version.
Alexandra
  • Like 4
