Kurt M Posted March 13, 2018 Share Posted March 13, 2018 Greetings I am rendering rednerworks export panoramas and I am getting strange errors. When the rendering is finished I looks like I am in a glass box. Anybody else having this issue ? I attached a sample note shadow line showing on walls, ceiling, floor, etc. I have a layer for lights in the file. If I have no lights and using only background lighting it doesn't show up . I filed a bug with tech support but wondering if others have had same issue. What settings for renderowks works best. How many lights ? Mahalo, Kurt Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted March 13, 2018 Vectorworks, Inc Employee Share Posted March 13, 2018 When you render the same scene in a normal non-pano rendering, in a viewport or on the design layer, does that same odd geometry appear? Have you seen this in any other files? If not, then I suspect it may be a bug, since the shape seems to follow the pano lines perfectly at a set distance from the viewer as you mentioned. I can recreate the issue and then file it if you can post or direct message me the file. Quote Link to comment
Andy Broomell Posted March 13, 2018 Share Posted March 13, 2018 @Kurt M - Take a look at this thread-- @Dave Donley suggests that you need to add lighting for panoramas to work, which is helpful to know, but also a bit disappointing functionally. Quote Link to comment
Kurt M Posted March 13, 2018 Author Share Posted March 13, 2018 Thanks Andy That is exactly what is happening. I will check it out. Did you just add a light like Dave suggested or did the add a camera do the trick ? Quote Link to comment
Andy Broomell Posted March 13, 2018 Share Posted March 13, 2018 I think by that point I had already given up on it (since it was just an auxiliary thing and not crucial to project), and I haven't played with panoramas since then But let us know what you figure out! Quote Link to comment
Kurt M Posted March 13, 2018 Author Share Posted March 13, 2018 adding multiple lights seemed to do the trick , Heres my sample pano. Thanks to all ! Quote Link to comment
