VW2018 - Architect borderline unusable (slow/crashes)
ckudi
Hi to all users
Our office has been using VW2018 (this also happened in 2017) and noticed a fantastic degradation in performance, reliability and stability.
The program has a time delay for all actions almost immediately this is not a phenomenon that progressively gets worse although the time delay in itself can get worse.
It is generally unstable with simple actions like the fill paint bucket tool causing the program to not respond indefinitely and crashing.
There is also another major problem which is the object info palette struggling to refresh at a rate which is useful.
Due to these problems the program is borderline unusable causing massive delays in drawing times.
We are strongly considering abandoning the software package for a suite that will just at the least be responsive in a manner which doesn't cause efficiency issues, which is a shame as the software itself offers a workflow we really enjoy.
All the office machines meet the minimum requirements and 1 machine in particular exceeds the requirements but is not free from the issues listed above (however it does not suffer the problems at the frustrating levels the other work stations do)
I have seen this issue or similar issues raised with little to no feedback. (But to acknowledge JimW, as he does respond but I am yet to find an answer which addresses the issues)
This is not a cheap package, and with the upgrade model the business is pushing we are constantly being pushed into updating every year to a newer version.... But why ? the previous version didn't work properly and the issues never got fixed. so why should we pay to upgrade to a newer version that also wont work.
We have contacted the local distributor and spoken with their tech department provided files, computer specs and from their side they have stated the solution was to start from scratch and build the master file as new, in an attempt to (if any exist)remove any errors in older files from being carried over into the new version. This was completed and solves nothing.
I know this is the wrong section but I cannot create a thread in the "known issues"
Any response is greatly appreciated.
9 answers to this question
Sorry can a admin/ moderator move this thread over to the troubleshooting section if this is not appropriate here.
Also if this helps the dxdiag information i see requested often.
System Information
      Time of this report: 3/8/2018, 16:37:10
             Machine name: NEATEFIVE
         Operating System: Windows 10 Pro 64-bit (10.0, Build 16299) (16299.rs3_release.170928-1534)
                 Language: English (Regional Setting: English)
      System Manufacturer: Gigabyte Technology Co., Ltd.
             System Model: Z87-HD3
                     BIOS: BIOS Date: 08/03/13 10:57:23 Ver: 04.06.05
                Processor: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz (8 CPUs), ~3.4GHz
                   Memory: 16384MB RAM
      Available OS Memory: 16334MB RAM
                Page File: 7523MB used, 25194MB available
              Windows Dir: C:\WINDOWS
          DirectX Version: DirectX 12
      DX Setup Parameters: Not found
         User DPI Setting: 96 DPI (100 percent)
       System DPI Setting: 96 DPI (100 percent)
          DWM DPI Scaling: Disabled
                 Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
           DxDiag Version: 10.00.16299.0015 64bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
      Display Tab 2: No problems found.
        Sound Tab 1: No problems found.
        Sound Tab 2: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
           Card name: NVIDIA GeForce GTX 960
        Manufacturer: NVIDIA
           Chip type: GeForce GTX 960
            DAC type: Integrated RAMDAC
         Device Type: Full Device
          Device Key: Enum\PCI\VEN_10DE&DEV_1401&SUBSYS_85201043&REV_A1
       Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
 Device Problem Code: No Problem
 Driver Problem Code: Unknown
      Display Memory: 10174 MB
    Dedicated Memory: 2007 MB
       Shared Memory: 8166 MB
        Current Mode: 1920 x 1080 (32 bit) (60Hz)
         HDR Support: Not Supported
    Display Topology: Extend
 Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
     Color Primaries: Red(0.647961,0.334484), Green(0.284680,0.607922), Blue(0.151867,0.071789), White Point(0.313000,0.329602)
   Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
        Monitor Name: Generic PnP Monitor
       Monitor Model: 2870
          Monitor Id: AOC2870
         Native Mode: 1920 x 1080(p) (60.000Hz)
         Output Type: HDMI
Monitor Advanced Color Capabilities: None
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
         Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvldumdx.dll
 Driver File Version: 23.21.0013.9077 (English)
      Driver Version: 23.21.13.9077
         DDI Version: 12
      Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
        Driver Model: WDDM 2.3
 Graphics Preemption: DMA
  Compute Preemption: DMA
            Miracast: Not Supported
 Hybrid Graphics GPU: Not Supported
      Power P-states: Not Supported
   Driver Attributes: Final Retail
    Driver Date/Size: 23-Jan-18 1:00:00 PM, 931584 bytes
         WHQL Logo'd: Yes
     WHQL Date Stamp: Unknown
           Vendor ID: 0x10DE
           Device ID: 0x1401
           SubSys ID: 0x85201043
         Revision ID: 0x00A1
  Driver Strong Name: oem38.inf:0f066de3d2368449:Section096:23.21.13.9077:pci\ven_10de&dev_1401
      Rank Of Driver: 00D12001
         Video Accel:
         DXVA2 Modes: DXVA2_ModeMPEG2_VLD  DXVA2_ModeVC1_D2010  DXVA2_ModeVC1_VLD  DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT  DXVA2_ModeH264_VLD_Stereo_NoFGT  DXVA2_ModeH264_VLD_NoFGT  DXVA2_ModeHEVC_VLD_Main  DXVA2_ModeHEVC_VLD_Main10  DXVA2_ModeMPEG4pt2_VLD_Simple  DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC
   Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
        D3D9 Overlay: Supported
             DXVA-HD: Supported
        DDraw Status: Enabled
          D3D Status: Enabled
          AGP Status: Enabled
       MPO MaxPlanes: 1
            MPO Caps: Not Supported
         MPO Stretch: Not Supported
     MPO Media Hints: Not Supported
         MPO Formats: Not Supported
    PanelFitter Caps: Not Supported
 PanelFitter Stretch: Not Supported
     Color Primaries: Red(0.637219,0.341320), Green(0.312023,0.625500), Blue(0.154797,0.054211), White Point(0.313977,0.329602)
       Monitor Model: 2870
          Monitor Id: AOC2870
         Output Type: DVI
         DDI Version: 12
         WHQL Logo'd: Yes
   Device Identifier: {D7B71E3E-5741-11CF-8650-2DA51BC2DA35}
           Vendor ID: 0x10DE
           Device ID: 0x1401
         Revision ID: 0x00A1
         Video Accel:
             DXVA-HD: Supported
          D3D Status: Enabled
          AGP Status: Enabled
       MPO MaxPlanes: 1
Sound Devices
            Description: 2870 (NVIDIA High Definition Audio)
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0072&SUBSYS_10438520&REV_1001
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: nvhda64v.sys
         Driver Version: 1.03.0036.0006 (English)
            WHQL Logo'd: Yes
          Date and Size: 15-Dec-17 12:00:00 AM, 226760 bytes
            Other Files:
        Driver Provider: NVIDIA Corporation
         HW Accel Level: Basic
              Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
            Description: Realtek Digital Output (Realtek High Definition Audio)
 Default Sound Playback: No
 Default Voice Playback: No
            Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1458A002&REV_1003
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: RTKVHD64.sys
         Driver Version: 6.00.0001.7535 (English)
            WHQL Logo'd: Yes
          Date and Size: 16-Jun-15 12:00:00 AM, 4504320 bytes
            Other Files:
        Driver Provider: Realtek Semiconductor Corp.
              Cap Flags: 0xF1F
              HW Memory: 0
Sound Capture Devices
            Description: Realtek Digital Input (Realtek High Definition Audio)
  Default Sound Capture: Yes
  Default Voice Capture: Yes
          Date and Size: 6/24/2015 23:57:00, 4504320 bytes
              Cap Flags: 0x1
           Format Flags: 0xFFFFF
Video Capture Devices
Number of Devices: 0
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: Splashtop Virtual Hid
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x00FF, 0xBACC
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
      Device Name: Micr
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x07B2
        FF Driver: n/a
      Device Name: Micr
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
      Device Name: Micr
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
      Device Name: Microsoft Hardware USB Mouse
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
      Device Name: Micr
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
      Device Name: Gaming Mouse G502
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC332
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub (USB 3.0)
| Vendor/Product ID: 0x8086, 0x8C31
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 12/12/2017 12:54:55, 555416 bytes
+-+ USB Composite Device
| | Matching Device ID: USB\COMPOSITE
| | Service: usbccgp
| | Driver: usbccgp.sys, 9/30/2017 02:41:08, 168856 bytes
| +-+ USB Input Device
| | | Matching Device ID: USB\Class_03&SubClass_01
| | | Service: HidUsb
| | | Driver: hidusb.sys, 9/30/2017 02:41:08, 40960 bytes
| | | Driver: hidclass.sys, 9/30/2017 02:41:08, 187392 bytes
| | | Driver: hidparse.sys, 2/10/2018 17:47:33, 46080 bytes
| | +-+ HID-compliant mouse
| | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | | Service: mouhid
| | | | Driver: mouhid.sys, 9/30/2017 02:41:08, 32768 bytes
| | | | Driver: mouclass.sys, 9/30/2017 02:41:08, 57240 bytes
| | | Service: HidUsb
| | +-+ HID Keyboard Device
| | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 9/30/2017 02:41:08, 40448 bytes
| | | | Driver: kbdclass.sys, 9/30/2017 02:41:08, 63384 bytes
+-+ Microsoft Mouse and Keyboard Detection Driver (USB)
| | Matching Device ID: USB\VID_045E&PID_07B2
| | Upper Filters: dc3d
| | Service: usbccgp
| | Driver: dc3d.sys, 12/9/2015 14:19:58, 95024 bytes
| | Driver: WdfCoInstaller01011.dll, 3/19/2014 15:27:44, 1795952 bytes
| +-+ Microsoft Hardware USB Keyboard
| | | Matching Device ID: usb\vid_045e&pid_07b2&mi_00
| | | Service: HidUsb
| | | Driver: coin99itp.dll, 11/12/2015 12:07:34, 466728 bytes
| | | | Service: kbdhid
| +-+ Microsoft Hardware USB Mouse
| | | Matching Device ID: usb\vid_045e&pid_07b2&mi_01
| | | Service: HidUsb
| | | Driver: coin99ip.dll, 11/10/2015 11:03:14, 466728 bytes
| | | | Service: mouhid
Gameport Devices
PS/2 Devices
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 334.8 GB
Total Space: 457.4 GB
File System: NTFS
      Model: SanDisk SDSSDA480G
      Drive: D:
      Model: HL-DT-ST DVDRAM GH24NSB0 SCSI CdRom Device
     Driver: c:\windows\system32\drivers\cdrom.sys, 10.00.16299.0015 (English), 9/30/2017 02:41:02, 159744 bytes
System Devices
     Name: High Definition Audio Controller
Device ID: PCI\VEN_10DE&DEV_0FBA&SUBSYS_85201043&REV_A1\4&1286464&0&0108
   Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 10.00.16299.0015 (English), 9/30/2017 02:40:59, 86016 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\drmk.sys, 10.00.16299.0015 (English), 9/30/2017 02:40:59, 96768 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\portcls.sys, 10.00.16299.0015 (English), 9/30/2017 02:40:59, 379392 bytes
Device ID: PCI\VEN_8086&DEV_8C20&SUBSYS_A0021458&REV_05\3&11583659&0&D8
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_50011458&REV_D5\3&11583659&0&E3
   Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 10.00.16299.0248 (English), 2/10/2018 19:06:11, 362904 bytes
     Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_E0001458&REV_06\4&1DCB0711&0&00E2
   Driver: C:\WINDOWS\system32\DRIVERS\rt640x64.sys, 9.01.0406.2015 (English), 9/30/2017 02:41:03, 604160 bytes
     Name: Intel(R) 8 Series/C220 Series PCI Express Root Port #3 - 8C14
Device ID: PCI\VEN_8086&DEV_8C14&SUBSYS_50011458&REV_D5\3&11583659&0&E2
     Name: Intel(R) 8 Series/C220 Chipset Family SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_8C02&SUBSYS_B0051458&REV_05\3&11583659&0&FA
   Driver: C:\WINDOWS\system32\DRIVERS\iaStorA.sys, 12.08.0000.1016 (English), 8/7/2013 14:23:46, 644968 bytes
     Name: Intel(R) Xeon(R) processor E3-1200 v3/4th Gen Core processor PCI Express x16 Controller - 0C01
Device ID: PCI\VEN_8086&DEV_0C01&SUBSYS_50001458&REV_06\3&11583659&0&08
     Name: Intel(R) Z87 LPC Controller - 8C44
Device ID: PCI\VEN_8086&DEV_8C44&SUBSYS_50011458&REV_05\3&11583659&0&F8
   Driver: C:\WINDOWS\system32\DRIVERS\msisadrv.sys, 10.00.16299.0015 (English), 9/30/2017 02:41:03, 18840 bytes
     Name: Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
Device ID: PCI\VEN_8086&DEV_8C31&SUBSYS_50071458&REV_05\3&11583659&0&A0
   Driver: C:\WINDOWS\system32\DRIVERS\USBXHCI.SYS, 10.00.16299.0125 (English), 12/8/2017 12:24:06, 437144 bytes
     Name: Intel(R) 8 Series/C220 Series SMBus Controller - 8C22
Device ID: PCI\VEN_8086&DEV_8C22&SUBSYS_50011458&REV_05\3&11583659&0&FB
   Driver: n/a
     Name: Intel(R) 8 Series/C220 Series PCI Express Root Port #1 - 8C10
Device ID: PCI\VEN_8086&DEV_8C10&SUBSYS_50011458&REV_D5\3&11583659&0&E0
     Name: Intel(R) 8 Series/C220 Series USB EHCI #1 - 8C26
Device ID: PCI\VEN_8086&DEV_8C26&SUBSYS_50061458&REV_05\3&11583659&0&E8
   Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 10.00.16299.0015 (English), 9/30/2017 02:41:08, 95640 bytes
   Driver: C:\WINDOWS\system32\drivers\usbport.sys, 10.00.16299.0015 (English), 9/30/2017 02:41:08, 454040 bytes
   Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 10.00.16299.0015 (English), 9/30/2017 02:41:08, 513944 bytes
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_88921458&REV_41\4&3AD3A588&0&00E3
     Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_8C3A&SUBSYS_1C3A1458&REV_04\3&11583659&0&B0
   Driver: C:\WINDOWS\system32\DRIVERS\TeeDriverW8x64.sys, 11.07.0000.1040 (English), 7/27/2017 08:47:50, 206496 bytes
     Name: NVIDIA GeForce GTX 960
Device ID: PCI\VEN_10DE&DEV_1401&SUBSYS_85201043&REV_A1\4&1286464&0&0008
   Driver: C:\WINDOWS\system32\DRIVERS\NVIDIA Corporation\Drs\dbInstaller.exe, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 464880 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\NVIDIA Corporation\Drs\nvdrsdb.bin, 1/24/2018 13:23:45, 1473020 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\NvContainerSetup.exe, 1.00.0007.0000 (English), 1/24/2018 13:23:45, 4181928 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\NvCplSetupInt.exe, 1.00.0007.0000 (English), 1/24/2018 13:23:45, 101308928 bytes
   Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\detoured.dll, 2.01.0000.0224 (English), 1/24/2018 13:23:45, 19952 bytes
   Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvd3d9wrap.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 219800 bytes
   Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 144592 bytes
   Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 2.01.0000.0224 (English), 1/24/2018 13:23:45, 19760 bytes
   Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvd3d9wrapx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 262536 bytes
   Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrapx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 171712 bytes
   Driver: C:\Program Files\NVIDIA Corporation\license.txt, 10/28/2017 06:50:09, 27203 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\MCU.exe, 1.01.5204.20580 (English), 1/24/2018 13:23:45, 849392 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvdebugdump.exe, 6.14.0013.9077 (English), 1/24/2018 13:23:45, 419312 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.1.pdf, 1/24/2018 13:23:45, 78094 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 8.17.0013.9077 (English), 1/24/2018 13:23:45, 509936 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 8.17.0013.9077 (English), 1/24/2018 13:23:45, 918088 bytes
   Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 2.00.0004.0000 (English), 1/24/2018 13:23:45, 438768 bytes
   Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll, 2.00.0004.0000 (English), 1/24/2018 13:23:45, 532040 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvlddmkm.sys, 23.21.0013.9077 (English), 1/25/2018 10:41:38, 17493824 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nv-vk64.json, 1/24/2018 13:23:45, 669 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvd3dumx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 18969472 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvd3dumx_cfg.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 19358800 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvinitx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 197992 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvldumdx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 931584 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvoglshim64.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 173432 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvoglv64.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 35404592 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvumdshimx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 577056 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvwgf2umx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 28909824 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvwgf2umx_cfg.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 29740528 bytes
   Driver: C:\WINDOWS\system32\NvFBC64.dll, 6.14.0013.9077 (English), 1/24/2018 13:23:45, 1126888 bytes
   Driver: C:\WINDOWS\system32\NvIFR64.dll, 6.14.0013.9077 (English), 1/24/2018 13:23:45, 988464 bytes
   Driver: C:\WINDOWS\system32\NvIFROpenGL.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 616240 bytes
   Driver: C:\WINDOWS\system32\nvDecMFTMjpeg.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 740336 bytes
   Driver: C:\WINDOWS\system32\nvEncMFTH264.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 1325384 bytes
   Driver: C:\WINDOWS\system32\nvEncMFThevc.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 1334808 bytes
   Driver: C:\WINDOWS\system32\nvEncodeAPI64.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 795928 bytes
   Driver: C:\WINDOWS\system32\nvapi64.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 4580832 bytes
   Driver: C:\WINDOWS\system32\nvcompiler.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 40269808 bytes
   Driver: C:\WINDOWS\system32\nvcuda.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 12843496 bytes
   Driver: C:\WINDOWS\system32\nvcuvid.dll, 7.17.0013.9077 (English), 1/24/2018 13:23:45, 4308976 bytes
   Driver: C:\WINDOWS\system32\nvfatbinaryLoader.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 1134768 bytes
   Driver: C:\WINDOWS\system32\nvinfo.pb, 1/24/2018 13:23:45, 48407 bytes
   Driver: C:\WINDOWS\system32\nvmcumd.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 618928 bytes
   Driver: C:\WINDOWS\system32\nvopencl.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 19796336 bytes
   Driver: C:\WINDOWS\system32\nvptxJitCompiler.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 13444552 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nv-vk32.json, 1/24/2018 13:23:45, 669 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvd3dum.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 15591424 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvd3dum_cfg.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 15912784 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvinit.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 171896 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvldumd.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 774304 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvoglshim32.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 145616 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvoglv32.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 27975152 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvumdshim.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 495352 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvwgf2um.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 24473608 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvwgf2um_cfg.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 25371952 bytes
   Driver: C:\WINDOWS\SysWow64\NvFBC.dll, 6.14.0013.9077 (English), 1/24/2018 13:23:45, 1054704 bytes
   Driver: C:\WINDOWS\SysWow64\NvIFR.dll, 6.14.0013.9077 (English), 1/24/2018 13:23:45, 939832 bytes
   Driver: C:\WINDOWS\SysWow64\NvIFROpenGL.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 506864 bytes
   Driver: C:\WINDOWS\SysWow64\nvDecMFTMjpeg.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 599352 bytes
   Driver: C:\WINDOWS\SysWow64\nvEncMFTH264.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 1043128 bytes
   Driver: C:\WINDOWS\SysWow64\nvEncMFThevc.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 1049480 bytes
   Driver: C:\WINDOWS\SysWow64\nvEncodeAPI.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 635248 bytes
   Driver: C:\WINDOWS\SysWow64\nvapi.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 3894304 bytes
   Driver: C:\WINDOWS\SysWow64\nvcompiler.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 35180016 bytes
   Driver: C:\WINDOWS\SysWow64\nvcuda.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 10900248 bytes
   Driver: C:\WINDOWS\SysWow64\nvcuvid.dll, 7.17.0013.9077 (English), 1/24/2018 13:23:45, 3709424 bytes
   Driver: C:\WINDOWS\SysWow64\nvfatbinaryLoader.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 885680 bytes
   Driver: C:\WINDOWS\SysWow64\nvopencl.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 16449872 bytes
   Driver: C:\WINDOWS\SysWow64\nvptxJitCompiler.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 11026080 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\VulkanRT-Installer.exe, 1.00.0065.0000 (English), 1/24/2018 13:23:45, 979288 bytes
   Driver: C:\WINDOWS\system32\nvdispco6439077.dll, 2.00.0049.0004 (English), 1/24/2018 13:23:45, 1976120 bytes
   Driver: C:\WINDOWS\system32\nvdispgenco6439077.dll, 2.00.0026.0002 (English), 1/24/2018 13:23:45, 1673616 bytes
     Name: Intel(R) 8 Series/C220 Series USB EHCI #2 - 8C2D
Device ID: PCI\VEN_8086&DEV_8C2D&SUBSYS_50061458&REV_05\3&11583659&0&D0
     Name: Intel(R) 4th Gen Core processor DRAM Controller - 0C00
Device ID: PCI\VEN_8086&DEV_0C00&SUBSYS_50001458&REV_06\3&11583659&0&00
   Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.16299.0015
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.16299.0015
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.16299.0015
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.16299.0015
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.16299.0015
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.16299.0015
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.16299.0015
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.16299.0015
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.16299.0015
DV Muxer,0x00400000,0,0,qdv.dll,10.00.16299.0015
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.16299.0015
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.16299.0015
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.16299.0015
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.16299.0015
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.16299.0015
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.16299.0248
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.16299.0015
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.16299.0015
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.16299.0015
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.16299.0015
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.16299.0015
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.16299.0015
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.16299.0015
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.16299.0015
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.16299.0015
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.16299.0015
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.16299.0015
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.16299.0015
DV Splitter,0x00600000,1,2,qdv.dll,10.00.16299.0015
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.16299.0015
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.16299.0015
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.16299.0015
Video Renderer,0x00800001,1,0,quartz.dll,10.00.16299.0015
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.16299.0015
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.16299.0015
Vectorworks Frame Source Filter,0x00200000,0,1,FrameSourceFilter.dll,
Video Renderer,0x00400000,1,0,quartz.dll,10.00.16299.0015
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.16299.0015
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.16299.0015
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.16299.0015
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.16299.0015
Overlay Mixer2,0x00200000,1,1,,
AVI Draw,0x00600064,9,1,quartz.dll,10.00.16299.0015
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.16299.0015
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.16299.0015
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.16299.0015
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.16299.0015
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.16299.0015
Null Renderer,0x00200000,1,0,qedit.dll,10.00.16299.0015
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.16299.0015
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.16299.0015
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.16299.0015
Smart Tee,0x00200000,1,2,qcap.dll,10.00.16299.0015
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.16299.0015
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.16299.0015
Wave Parser,0x00400000,1,1,quartz.dll,10.00.16299.0015
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.16299.0015
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.16299.0015
File stream renderer,0x00400000,1,1,quartz.dll,10.00.16299.0015
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.16299.0015
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.16299.0015
AVI Mux,0x00200000,1,0,qcap.dll,10.00.16299.0015
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.16299.0015
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.16299.0015
File Source (URL),0x00400000,0,1,quartz.dll,10.00.16299.0015
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.16299.0015
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.16299.0248
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.16299.0015
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.16299.0015
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.16299.0015
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.16299.0248
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.16299.0015
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.16299.0248
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.16299.0015
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.16299.0015
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.16299.0015
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.16299.0015
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.16299.0015
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.16299.0015
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.16299.0015
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.16299.0015
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.16299.0015
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.16299.0015
Audio Capture Sources:
Realtek Digital Input (Realtek High Definition Audio),0x00200000,0,0,qcap.dll,10.00.16299.0015
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.16299.0192
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.16299.0192
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.16299.0192
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.16299.0015
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.16299.0015
WDM Streaming Capture Devices:
Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,10.00.16299.0015
Realtek HD Digital input,0x00200000,1,1,ksproxy.ax,10.00.16299.0015
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,10.00.16299.0015
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,10.00.16299.0015
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,10.00.16299.0015
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,10.00.16299.0015
,0x00000000,0,0,,
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.16299.0015
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.16299.0015
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.16299.0015
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.16299.0015
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.16299.0015
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.16299.0015
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.16299.0015
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,10.00.16299.0192
Encrypt/Tag,0x00200000,0,0,EncDec.dll,10.00.16299.0192
PTFilter,0x00200000,0,0,EncDec.dll,10.00.16299.0192
XDS Codec,0x00200000,0,0,EncDec.dll,10.00.16299.0192
WDM Streaming Communication Transforms:
Audio Renderers:
2870 (NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,10.00.16299.0015
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.16299.0015
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.16299.0015
DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.16299.0015
DirectSound: 2870 (NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,10.00.16299.0015
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
  <transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
  NVIDIA MJPEG Video Decoder MFT, {70F36578-2741-454F-B494-E8563DDD1CB4}, 0x4, 8, nvDecMFTMjpeg.dll, 23.21.0013.9077
  Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.16299.0248
  DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.16299.0015
  Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.16299.0015
  Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.16299.0248
  WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.16299.0015
  WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.16299.0015
  MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.16299.0015
  Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.16299.0015
  Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}, 0x1, MSVP9DEC.dll, 10.00.16299.0248
  Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.16299.0015
  HEVCVideoExtension
Video Encoders:
  NVIDIA H.264 Encoder MFT, {60F44560-5A20-4857-BFEF-D29773CB8040}, 0x4, 8, nvEncMFTH264.dll, 23.21.0013.9077
  NVIDIA HEVC Encoder MFT, {966F107C-8EA2-425D-B822-E4A71BEF01D7}, 0x4, 8, nvEncMFThevc.dll, 23.21.0013.9077
  H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.16299.0015
  WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.16299.0248
  Microsoft MF VPX Encoder Transform, {AEB6C755-2546-4881-82CC-E15AE5EBFF3D}, 0x1, MSVPXENC.dll, 10.00.16299.0015
  H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.16299.0015
  WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.16299.0015
  Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.16299.0015
  HEVCVideoExtensionEncoder
Video Effects:
  Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.16299.0015
  Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.16299.0015
  VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.16299.0015
  Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.16299.0015
  Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.16299.0015
Video Processor:
  Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.16299.0098
Audio Decoders:
  Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.16299.0015
  MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.16299.0015
  WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.16299.0015
  Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.16299.0015
  A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.16299.0248
  GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.16299.0248
  WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.16299.0015
  Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.16299.0015
  Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.16299.0015
  Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.16299.0015
  WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.16299.0015
  G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.16299.0248
  IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.16299.0248
  MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.16299.0015
  Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.16299.0015
  ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.16299.0248
  Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.16299.0015
  DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.16299.0015
Audio Encoders:
  LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.16299.0015
  MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.16299.0248
  Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.16299.0015
  WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.16299.0015
  MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.16299.0015
  Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.16299.0015
  WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.16299.0015
  Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.16299.0015
  Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.16299.0015
  Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.16299.0015
Audio Effects:
  AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.16299.0015
  Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.16299.0015
Multiplexers:
  Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.16299.0064
Others:
  Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.16299.0248
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableDecoders = 1
EnableEncoders = 1
EnableVideoProcessors = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
{A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{30395056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
{30385056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket , type 0
Event Name: AppHangB1
Response: Not available
Cab Id: 0
Problem signature:
P1: Vectorworks2018.exe
P2: 23.0.2.0
P3: 5a541f61
P4: 3b74
P5: 134217728
P6:
P7:
P8:
P9:
P10:
+++ WER1 +++:
Event Name: AppHangTransient
Cab Id: 0
Problem signature:
P2: 23.0.2.0
P3: 5a541f61
P4: unknown
P5: unknown
P6: unknown
P7: unknown
P8:
P9:
P10:
+++ WER2 +++:
Fault bucket 129580992988, type 5
Event Name: RADAR_PRE_LEAK_64
Cab Id: 0
Problem signature:
P1: CineRenderNEM.exe
P2: 18.0.5.8
P3: 10.0.16299.2.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER3 +++:
Cab Id: 0
Problem signature:
P2: 23.0.2.0
P3: 5a541f61
P4: a801
P5: 134217728
P6:
P7:
P8:
P9:
P10:
+++ WER4 +++:
Fault bucket 1250722863414590646, type 5
Event Name: RADAR_PRE_LEAK_WOW64
Cab Id: 0
Problem signature:
P1: AcroRd32.exe
P2: 18.11.20038.5321
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER5 +++:
Fault bucket 1572764199385109353, type 5
Event Name: WindowsUpdateFailure3
Cab Id: 0
Problem signature:
P1: 10.0.16299.248
P2: 800704cf
P3: 00000000-0000-0000-0000-000000000000
P4: Scan
P5: 0
P6: 0
P7: 0
P8: <<PROCESS>>: AgentPackageWindowsUpdate.exe
P9: {8B24B027-1DEE-BABB-9A95-3517DFB9C552}
P10: 0
+++ WER6 +++:
Cab Id: 0
Problem signature:
P1: 10.0.16299.248
P2: 800704cf
P4: Scan
P5: 0
P6: 0
P7: 0
P10: 0
+++ WER7 +++:
Cab Id: 0
Problem signature:
P1: 10.0.16299.248
P2: 800704cf
P4: Scan
P5: 0
P6: 0
P7: 0
P10: 0
+++ WER8 +++:
Event Name: APPCRASH
Cab Id: 0
Problem signature:
P1: GIB EzyBrace®.exe
P2: 1.0.0.0
P3: 57b4f74f
P4: KERNELBASE.dll
P5: 10.0.16299.248
P6: 13ae3814
P7: c000041d
P8: 001008c2
P9:
P10:
+++ WER9 +++:
Event Name: CLR20r3
Cab Id: 0
Problem signature:
P1: WIN5ZDTNVII11ZO1TGEL1CLQLEA5TUCM
P2: 1.0.0.0
P3: 57b4f74f
P4: System.Windows.Forms
P5: 4.7.2556.0
P6: 59b8360c
P7: 2c8c
P8: 168
P9: System.ComponentModel.Win32
P10:
Edited by ckudi
I am just a moderator, and I don't work for VW/Nemetschek, but I did move your post per your request.
I am very sorry that you are having trouble with VW, but about the only think I can say is that there are many other people that are not having trouble. There are people here on the forum and at VW who would be glad to try and work with you to try and figure out your problem, but it is not a general problem that most of the user (myself included) are experiencing.
I fully believe that you are having a problem and if you are willing to work with us here on the forum and tech support, it is likely that it can be solved. Probably not a quickly as you would like, but solved none the less.
I am not intending to minimize your problem, just let you know that not everyone is having the same experience.
Hi Pat
Thank you for doing that.
Yes I understand that is somewhat of a blanket statement saying that others are having similar problems. as specific incidents vary greatly between users depending on machine and version of software.
But a simple google search with the key phrase vectorworks running slow has hits which in vague recollection resemble my issues but have no fixes.
We are willing of course and greatly appreciate any time and help anyone can provide.
We are also noticeably seeing hang times with text and deleting items.
@ckudi I’m sorry to hear that you’re having this experience as well. I haven’t heard of this particular issue either, so I too don’t think this a general problem... which means there must be a cause. Now it’s just a matter of finding the cause. Patience and perseverance will typically get you there. (Switching to another application will just get you THAT applications issues.)
I’m curious...
- Are you seeing the issue with ALL files or just certain files? Does it occur even with brand new blank files not made from a template?
- Are you working on files that are stored on a server or are they stored on your computer?
- Are all of your graphics drivers up to date, and are you 100% sure of this? (In some cases, drivers on Windows machines may not update with the various automatic updates, so driver updates should be checked for and done manually from the graphics card manufacturer’s website.)
- Can you post a file in which you’re seeing the issue?
Thanks.
Hi NeilB
Thanks for your response.
This is happening in all files on all of our work stations. the only workstation that was not affected was the laptop which used exactly the same files. (this has since unfortunately stolen in a burglary and cant be used as a reference point to eliminate problems between the machines)
The director has been going through the process of starting a new office template file from scratch and experienced the same issues. (I will confirm this with him though just to be doubly sure)
The files are not locally stored, they are retrieved from the office network server.
The graphics card update was the first response we got from our local distributor and their in house tech guy. This was done and did not fix the issue.
(from memory it was not manually done but through the nvidia experience program, I will manually update to see if there is any change in performance)
I'm sure I will be able to post a example file here. I will need to check with the office director first though. (example file pending)
I also just noticed (but I don't know what I am looking at) in the dxdiag above under dianostics there are errors with the line "apphangB1" and "apphangtransient" relating to VW2018.exe.
The thread listed below seemed to sound similar to how our issue is. we also had similar problems in 2017, but I personally did not spend much time at this version as I was upgraded to VW18 quite quickly.
and the fix of refreshing the workstation user did not work for us.
@ckudi Hearing that your Vectorworks files are stored on a server makes me wonder... Do you have the same issue when working on a file that is stored locally on your own computer? If you haven’t tested this yet, please do.
Having a server, a network, and network traffic, as part of the issue introduces so many variables (that are beyond the scope of Vectorworks) that it’s often best to troubleshoot using locally stored files to remove those variables. Since you mention that you had similar problems in v2017 I am especially suspicious that the server or network may be involved in the problem you are seeing.
Also, have you received permission to share a file here yet?
I have this problem as well, for well over a year now. I'm using Vectorworks 2018 on a Macbook pro running Sierra. Vectorworks has become almost unusable. Simple actions like editing text cause terrible lag, which gets progressively worse during each session. Every hour or so Vectorworks will crash or freeze, and I often have to reboot my computer. I am only using the software for 2d construction drawings, using the most basic features. I paid over $7,000 CAD for this software so I'm extremely angry and disappointed. Vectorworks has never managed to address these issues. I see dozens and dozens of forum posts complaining about the same issues, and never any progress indicated or solutions provided. At this point I am on the edge of going back to Autocad, at least I know that it's stable.
Hi @Innes, this level of performance is not typical, therefore a cause or causes should be able to be determined and rectified. Please contact your local distributor for support.
Here's a quick (incomplete) list of variables that could be cause or contribute to your symptoms:
Hardware resources are being pushed to their limit. (2D objects only or not). In order of likelihood:
  1. Insufficient Memory available or the rate of 'swap' is higher than your computer can keep up with. 'Memory pressure,' too high. (Common).
  2. Hard drive getting full. (Fairly common). This can compound the above problem.
  3. Hard drive getting old/slow. (Rare, so unlikely cause). This can compound the aforementioned memory problems.
Given the nature and pattern of your symptoms, I think hardware burdens (above) are the most likely cause for you. I suggest: Open Activity Monitor and keep it visible while you work. Use the Help menu to learn how to appreciate the readouts, but in the Memory tab, Memory Pressure will probably be the most important readout.
Other potential causes:
  1. Far Out Objects could be present in your drawing/s. (Highly common and affects all CAD programs). - See this post which includes a guide on correcting this condition.
  2. One or more corrupt objects.
  3. Vectorworks not up-to-date. - If you're not already on Service Pack 6, then that should be your first objective.
  4. One or more corrupt resources.
  5. Graphics card drivers (macOS) needs to be reinstalled. (I've never had need to prescribe this to-date).
