Lett Posted August 5, 2004 Share Posted August 5, 2004 I have been reading post on this meesage board for the last while and I must admit I'm a little confused about the importing of DWG's in version 11. Am I correct in assuming that I can now import X-referenced DWG files as long as I have all the documents? If so, that's a good enough reason alone to upgrade. Quote Link to comment
hong Posted August 6, 2004 Share Posted August 6, 2004 To be clear, you can import a whole folder of dwgs into one vectorworks file in VW11. If these dwgs are xreferenced each other correctly, yes they will show up as it is in this one VW file as different layers. I don't think VW11 will automatically trigger to import all xrefs by just importing one file that has xrefs. Quote Link to comment
Guest Posted August 8, 2004 Share Posted August 8, 2004 The xrefs have to be bound to the file in order for them to import. Quote Link to comment
