jamesmise
Hidden Line Rendering not correct
Hidden Line rendering is not displaying correctly in front or back views.  Other views are correct.  Attached are some samples and a VW file.  Sample 1 shows what a front view, hidden line rendering should look like.  I had to cant the model a small fraction to get it to render correctly.  Sample 2 is a Front view, hidden line rendering and is showing lines that should be hidden, especially in the bottom center of the model.  Sample 3 is an isometric view of the model.   Any help is appreciated.  I can't keep printing my drawings out and whiting out the incorrect lines.
Vectorworks 2018 with Renderworks
vw problem.vwx
Edited by jamesmise
I think this might be a bug with how container objects are rendered in hidden line. If I convert a copy of your symbol to a group and then ungroup it the objects draw correctly. If I regroup the objects, the problem reappears. It happens when rendering with hidden line in both the design layers and sheet layers. I would bug submit it.
Kevin
5a9ef4ef6641b_ScreenShot2018-03-06at12_06_45PM.thumb.png.9fea74654a48863f010b85bf22bef948.png
I tried what you said, but at first I did not also convert the sub-objects (the casters).  It did not fix the problem.  I tried it again and converted it to a group including the sub-objects and the rendering was correct.
So it may have something to do with symbols contained within symbols.  And as I said, the rendering was incorrect in front and back views only.  Side views and isometric views were fine.
I will submit it as a bug.
Thanks for your help!
One other note.  I noticed that section viewports are not corrected after the process you described.  I'm still working on a way for the section viewport to display correctly.
I played with it some more and have attached a fixed symbol version here. Not entirely sure what is causing it. It happens in all true views (eg. if I rotate the original symbol 90 degrees the problem shows up in the side views). For the fixed version I made 3 changes -
  1. I made a solid addition from the metal parts of the caster symbol.
  2. I made a new extrude for the back structure that extruded 3 of the parts together.
  3. I cut and pasted back the front deck piece.
These simple changes seem to have solved it. Give this version a try and see if it does all you need.
A VW mystery....
Kevin
vw problem KM.vwx
Thanks Kevin.
I believe the casters were pulled from the Sketchup 3D Warehouse.  Maybe that has something to do with it.
I took a look at the original symbol and there is a rogue single line in the symbol. Once deleted, it seems to work as normal.
Mark
Interesting. I deleted the same line when I was editing it too. But if I edit the original and only delete the line it doesn't fix the problem on my install.
What's even weirder is when I pan the drawing, the rendering adjusts to be correct but as soon as I release the mouse button it redraws as incorrect again.
Kevin
Here is my finding. When creating a section viewport the lines hide correctly. But you are correct, directly in design layer, a hidden line rendering does not look correct.
@markdd seems to have found it.  I've accidentally done this before myself.  I guess every symbol you get from another source like 3d Warehouse, should be opened in a separate file in Vectorworks and thoroughly examined before adding it to a master drawing.  Learned my lesson.
