How to call up Extrude thickness in Worksheets?
M5d
I thought this would be easy (and it probably is), but I can't see it. Detailing steelwork, base plates and cleats etc. with extrudes, how do you call up the thickness or depth of the extrude in a worksheet?
WIDTH and HEIGHT gets you X and Y in the image below:
Also, if anyone has any know-how or experience in detailing and listing steelwork parts, I'd like to know how you do it . . .
3 answers to this question
I had a go at this today.
The problem with the length, width, height functions is that if the object is rotated, these values change. Please see:
Another problem was negative extrusion values.
In the end I used the following formulas in the worksheet:
=SQRT(LENGTH*LENGTH)
=SQRT(WIDTH*WIDTH)
and to get the proper height for 90 degrees rotated extrudes
=SQRT((VOLUME*1000000/LENGTH/WIDTH*1000)*VOLUME*1000000/LENGTH/WIDTH*1000)
The silly multipliers are to get rid of the mm/m3 difference. The SQRT keeps the numbers positive.
I guess in the end the above works for extrusions that are orthogonal to 2D plan, but not tilted.
