Currently I'm trying to figure out ways to modify the sweep I just created. I want to trim/cut a section of it off. However, if I convert the sweep to anything such as a solid, the sweep turns into a filled solid. How can I convert a sweep into a surface and thus trim the section off from the new surface?
If you still want the sweep object to remain a sweep object, then the best way to do this is to edit the underlying sweep profile. If you double-click on the sweep, you will find the original geometry which you can then edit accordingly. (you may have to switch to Top/Plan when inside the edit window to see the geometry clearly)
Edited by markdd
