Nedsmar Posted March 3, 2018 Share Posted March 3, 2018 Could the object info display both say sq m and sq ft at same time as I am often asked for both and would save having to change units each time. Quote Link to comment
0 Art V Posted March 8, 2018 Share Posted March 8, 2018 Or for any property in the object info palette, e.g. have two columns, the first one in the drawing units and the second column in a different unit, e.g. m/ft or mm/inch where you can fill out any of the two to adjust things. e.g. my main unit is m, but I do get dimensions in ft so if there would be a second column for height and width I could set that to ft and then update dimensions in there instead of having to type the unit all the time. Of course it should still be possible to use unit overrides e.g. put in something in inches and then use the unit with the input, in either column. Quote Link to comment
Nedsmar
1 answer to this question
