Mikedk64 Posted March 2, 2018 Share Posted March 2, 2018 Hi, I have this single layer wall (100 mm). The wall has its color, fill etc. attributes from a class. In this class, I have drawn my own tile, as I use as the fill. This works great when I do a section view in the wall and looking from the front. So far so good. But now I want to have a section view looking from the top, and in this section I dont want the same fill in the wall. Is there a way to have 2 different fills for a wall, maybe controlled by two different classes or maybe something else. Quote Link to comment
markdd Posted March 2, 2018 Share Posted March 2, 2018 In the section viewport, use class overrides. In the Section Viewport, select the class you want the different fill to be in double-click to edit. Change the fill to what you want and that should work. Be sure that in the advanced properties of the viewport you have this kind of configurations set up. Quote Link to comment
Mikedk64 Posted March 6, 2018 Author Share Posted March 6, 2018 Thanks so much Markdd! Quote Link to comment
