MaWi
Input Node OIP in Wrapper
Hi Marionette Fans
Is it possible to create a Input Node for the OIP which can stored in a Wrapper? At the moment I use a "pass" in the Wrapper. Because I use the same Wrapper more than once in the same Marionette Object it would be helpful if I can store the Input Node in the Wrapper.
Best regards, Marc
Hi Marc,
Can you elaborate on this? I'm not sure I understand the question.
A small file with an example would be helpful, or even just some screenshots.
Hi Marissa
Thanks for your feedback. Attached a file. Is it possible to use a Input Node like "Wall Style" (01 Name Wandstil) directly in the Wrapper ? While I was teaching Marionette this question was brought to me. As you can see, I used a Pass Node in the sample. This works technically fine.
Best regards, Marc
Sample_Marionette_Forum.vwx
If you want that input exposed in the OIP after you convert to a Marionette object, then you will have to use the pass node as you've done. I don't think there's a way to expose input nodes inside wrappers of Marionette objects to the OIP.
