J. Wallace Posted February 27, 2018 Share Posted February 27, 2018 (edited) Hello everyone. I have just started a file in which I've made a small site model (.5 acre). The model looks good but when I apply a pad to represent the existing driveway it does not modify the model. Things I have done: Grade limits in place outside the pad and inside the model area All modifers and model has there 3d settings are set to existing I've updated the model multiple times Site model is on it's own layer along with modifers, modifersin their own class - Site-DTM-Modifier 2d overhead contours look good but as you can see the pad doesn't effect the model surface Thanks for you feedback advance. Edited February 27, 2018 by J. Wallace Quote Link to comment
AlanW Posted February 27, 2018 Share Posted February 27, 2018 @J. WallaceHi, Set your site model to show proposed, not existing. Quote Link to comment
J. Wallace Posted February 27, 2018 Author Share Posted February 27, 2018 Thanks @Alan WoodwellChanged those settings and I'm still getting the same results Quote Link to comment
AlanW Posted February 27, 2018 Share Posted February 27, 2018 @J. WallaceHi check this setting. Site Model.vwx Quote Link to comment
J. Wallace Posted February 27, 2018 Author Share Posted February 27, 2018 (edited) Yep...same result? Edited February 27, 2018 by J. Wallace Quote Link to comment
J. Wallace Posted February 28, 2018 Author Share Posted February 28, 2018 Problem solved...grade limits just went outside the site model...thanks for your help @Alan Woodwell Quote Link to comment
