Bruce Kieffer Posted February 27, 2018 Share Posted February 27, 2018 Is it possible to join walls that are on different layers?" I am unable to make that happen. Quote Link to comment
Diego - Resuelvector Posted February 27, 2018 Share Posted February 27, 2018 If you want to join the walls using the Wall Join tool, I'm afraid you cannot do that, the walls are layer dependant, so you can only join walls in the same layer. Quote Link to comment
Guest Wes Gardner Posted February 27, 2018 Share Posted February 27, 2018 Here are a couple of walls on different layers...they join up fine. You'll need to have "Show,Snap, Modify Others" ON in your layer controls. I'll bet your scenario is a bit more complicated than a simple "L" join. Wall and Layers.vwx Quote Link to comment
Bruce Kieffer Posted February 28, 2018 Author Share Posted February 28, 2018 I can get the walls to join in your drawing, but not in mine. I even tried new walls on the same layer with the same class in my drawing. The wall join tool does nothing but beep and gives me a meaningless message. Quote Link to comment
Bruce Kieffer Posted February 28, 2018 Author Share Posted February 28, 2018 I restarted Vectorworks and it seems to be working now. Go figure. Quote Link to comment
