We all recently received a requests to fill out a feedback survey. The first item was to provide the top 5 areas of Vectorworks we would like to see improvement. I was able to write out 4 of them on a bus to NYC to visit a few job sites.
I'd like to provide these as public requests for other users to give input, as i believe i'm not the only one with some of these concerns.
Please read, hopefully enjoy, and let me know if you have anything to add, or simply just vote for one or all of these as areas that need improvement/fixing.
1: Our main frustration is slow down on a majority of our files.
Windows machines in particular seem to have more issues with panning, zooming etc. Our three main workstations for Vectorworks consist of: 32+ gb of ram; 4+gb of dedicated video ram; intel core i7+ processors; 500+ gb SSD system drives. Far higher than recommended specifications. Side note; I would recommend that your main page for "system recommendations" include a section regarding multiple applications running alongside Vectorworks which I believe is valid for most of your customers. I believe all numbers on that page only pertain to Vectorworks running alone on said machine.
We have found some work-arounds such as turning off layers with reference information from external files, pdf's etc. However, there are still some files that no workaround can cure.
I have read the article from JimW regarding single threaded cpu vs multithread/gpu features/modules which really helped us understand what types of hardware are worth spending extra $$ on and which ones won’t help at all.
It sounds like Nemetschek is on the right track with migrating bits of the software to more modern processing methods, but seems like it may be a long painful path for its users; since more complex "wow" features are being implemented each year, while the processing power to do the heavy lifting doesn't seem to be as high of a priority to support these new features.
2: Unconstrained dimension tool: in 2015, 16 & 17 our team has become used to the N button for constrained and M for unconstrained dimensions. 2018 has changed the M key to toggle multiple view mode. I would ask that this be reverted back to the previous standard. It is very convenient for the M & N keys to be right next to each other and I believe key commands for dimensioning are going to be used more broadly among your user base compared to the multi view mode.
3: The dashed lines which control dimension baseline offset seem to take selection priority over the grip for moving either end of the dimension to a different snap point. I have seen this primarily when zoom levels are at a lower percentage (zoomed out farther). Dimension end grips should definitely take a higher selection priority over the baseline offset as I believe these grips are used at a higher frequency, especially during the revision process.
4: "Always do the selected action" choices: The reset saved settings dialog for this check box in particular can be frustrating as a "broad reset". I believe it would be highly beneficial to productivity to expand this checkbox to individually select which particular dialog is to be reset. On multiple occasions I have accidentally locked the wrong option due to the fast paced environment many of us work in. If the user knows which particular dialog is locked to the wrong setting (i.e. yes or no), one could open the "reset saved settings" dialog and undo only what is necessary. Having the "always do..." check box is great for productivity but is too easily undone by one mistaken click of the mouse.
Chris Brough
3 answers to this question
