Bruce Kieffer Posted February 24, 2018 Share Posted February 24, 2018 I want to delete a class but I get this dialog message saying the class is required... How do I find the plug-in object the message is referring to? It appears there are no objects in the class. Quote Link to comment
zeno Posted February 24, 2018 Share Posted February 24, 2018 Try to enable and disable manually the class. All design layer on.. it is not very professional but for me, it works every time I'm in the same situation... But yes, something like right click on the class name>select all object in this class should be very useful. Quote Link to comment
Bruce Kieffer Posted February 24, 2018 Author Share Posted February 24, 2018 No objects reside in the class on any layer. Quote Link to comment
zeno Posted February 24, 2018 Share Posted February 24, 2018 Do you have something on resource browser? Like a door style or similar? Quote Link to comment
Bruce Kieffer Posted February 24, 2018 Author Share Posted February 24, 2018 Just now, Zeno said: Do you have something on resource browser? Like a door style or similar? Yes, many. I will delete the unused resources, and review the setting of the others. Quote Link to comment
zeno Posted February 24, 2018 Share Posted February 24, 2018 1 minute ago, Bruce Kieffer said: Yes, many. I will delete the unused resources, and review the setting of the others. Exactly. It is the right way I mean. Quote Link to comment
zeno Posted February 24, 2018 Share Posted February 24, 2018 Try to see on File>Document info if you can understand how many 2D-3D objects are in the class. It could help you to better understand. Quote Link to comment
Bruce Kieffer Posted February 24, 2018 Author Share Posted February 24, 2018 4 hours ago, Zeno said: Try to see on File>Document info if you can understand how many 2D-3D objects are in the class. It could help you to better understand. Where is that exactly? Quote Link to comment
zeno Posted February 24, 2018 Share Posted February 24, 2018 In Italian version is in the file menu>document info or info document (I don't know exactly, I attached some screenshot) Quote Link to comment
Bruce Kieffer Posted February 24, 2018 Author Share Posted February 24, 2018 Not in the US version, and I don't see any menu item like that in the Workspace Manager. File Info on mine is not it. Quote Link to comment
AlanW Posted February 24, 2018 Share Posted February 24, 2018 @Bruce KiefferHi, Have you done a purge?? Quote Link to comment
Bruce Kieffer Posted February 24, 2018 Author Share Posted February 24, 2018 12 minutes ago, Alan Woodwell said: @Bruce KiefferHi, Have you done a purge?? @Alan WoodwellYes, but it removed a lot of items. I will go back to that and be selective and see what happens. Quote Link to comment
Bruce Kieffer Posted February 25, 2018 Author Share Posted February 25, 2018 I deleted a bunch of unused resources that had no effect on my drawing and then I was able to delete the class. Quote Link to comment
