Importing a Vectorworks drawing as a referenced viewport
StatonCohen
Check the correct classes and layers are on.
check if the viewport crop is in the correct place.
Check the viewport is in the correct projection I.e. Top plan , orthoganal etc.
If the viewport is  3D projection check the render style.
you could also try the eye dropper tool to copy attributes from the correctly displaying viewports to the one you are having trouble with.
Cheers
