Importing DWG and Viewport Scaling Issues
AB_151995
Hi All,
Hoping that you can help me, I'm still learning the basics of VW, but I've never had to import a dwg etc before. I have a cad file which has to be at 1:500 on either an A1 or A0 (in this instance it is an A0) I imported the dwg as > Import single DXF / DWG into VW changed the units to > Use Vectorworks Document Units and chose >This Scale and clicked 1:500. Everything seemed ok until I created a viewport and sheet layout - I set up the sheet layout as an A0 and  when the viewport comes in at 1:500 it is tiny I even tried it on an A4 and I couldn't even see the viewport as it was that small! I hope that makes sense. :)
Please someone tell me what im doing wrong?
