mike-h Posted February 16, 2018 Share Posted February 16, 2018 Apologies if this has been answered before - but if it has I can't find it! Although we produce drawings at A1/A2, we like specifications and schedules to be A4/ A3. I'm currently trying to produce a project wide specification as a series of database linked keynotes with more detailed specs in a keynote legend that forms a separate document. I'd expect this to run over, perhaps 10 sheets of A4 but I can't see how to break the legend over these pages (I want it to be a single legend as I want it to sort alphabetically). Is this possible? Likewise for a window schedule with images (or any other worksheet) - I want to set up a decent image/ font size and allow it to flow over multiple pages. Thanks! Mike Quote Link to comment
JMR Posted February 24, 2018 Share Posted February 24, 2018 I've searched for this functionality, too. I guess one can't? A wishlist item? Quote Link to comment
zeno Posted February 24, 2018 Share Posted February 24, 2018 Hello I'm not totally sure I'm got it, but: Do you need something like multiple pages in a sheet layer or what? Quote Link to comment
RickR Posted February 25, 2018 Share Posted February 25, 2018 I've used two solutions. Preferred method: Break the schedule into parts by the criteria. "ID# <50" or something for the first page. Then duplicate the worksheet but change to "ID# <=50" The major drawback is that you have to manually place the split. So if things change much you can get funny lengths. Method 2: Create and reference a PDF. Create the raw table without headers and save as a PDF. Pages 2+ will not have headers no matter what. Then draw several versions of the header on the sheet. Import the PDF pages as references and place them under the header objects. Now every time you update things you re-create the PDF and the sheet gets refreshed. The drawbacks are mostly the PIA handling and setting it up. Quote Link to comment
Jonathan Pickup Posted February 26, 2018 Share Posted February 26, 2018 I have used viewports to do this Quote Link to comment
JMR Posted February 26, 2018 Share Posted February 26, 2018 Thanks, I do use criteria to divide the worksheet into parts. However, one ends up with multiple worksheets. The viewport method works but the problem there is that an additional worksheet item on the 1st sheet pushes the rows down on other worksheets as well. This can be a problem with revisioning, since it's not easy to notice, and changing the amount of data on one sheet changes all sheets that come after it as well. Some other software packages are able to create a set of a4's for door elevations, for example. I guess a VW implementation would be a set of sheet layers or "sub sheet layers". Maybe this functionality is not easy to implement due to the way VW sheet layers are set up. Quote Link to comment
mike-h Posted February 26, 2018 Author Share Posted February 26, 2018 Thanks all - JMR - do you mean that you then have a worksheet for each page, as it were? What are the issues there - does that lead to info being easily missed off? Jonathan - if using viewports, do you have to create a big sheet layer that has the master worksheet on, and then viewport to further sheet layers from there? This has the potential to be quite a big drawback for us. One of the key things we 'bought into' with VW was the pseudo Desktop Publishing capabilities, but I have the same problem with text documents that frequently run over 20-30 pages. Every time I edit them I have to make the page breaks work by cut/pasting a bit from the end of a page onto the next page, triggering a domino effect through the document. I don't like the viewport options really as that is what we did with ACAD, and I was forever dragging handles around to try to make sure that all text was visible as intended. I would think it is really a key issue for many that text and worksheet data can 'flow' seamlessly from one page/ sheet to the next. Quote Link to comment
mike-h Posted February 26, 2018 Author Share Posted February 26, 2018 PS... Whereabouts do you place "the criteria. "ID# <50"" - if I look under the 'Insert' menu of the worksheet, I see criteria, but no options for a text based formula. Apologies if I'm missing something obvious, but I'm pretty new to the worksheets and finding the available information pretty patchy and spread around across various versions (including VW info, archoncad etc). It would be great to see a really comprehensive, up to date set of videos on this. :-) Quote Link to comment
JMR Posted February 26, 2018 Share Posted February 26, 2018 @mike-h: Using limiting criteria (room number, record field etc) does enable one to "limit" the worksheet to a single page. In other words, each worksheet contains so little information that it fits on one sheet. Where this might be problematic is that if you want to change the actual worksheet arrangement, you have to change 20 different worksheet if you have 20 sheet layers. I used the viewport method in a couple of projects but in the end it was too difficult to keep track when changes occurred. Quote Link to comment
JMR Posted February 26, 2018 Share Posted February 26, 2018 Enclosed is a screenshot, you can use field value, location etc. to limit the amount of data in a spreadsheet. Quote Link to comment
mike-h Posted February 26, 2018 Author Share Posted February 26, 2018 Thanks again, though I'm afraid I'm still having trouble with the field value method. I was going to try filtering all first floor windows - these have a prefix "W-1-". See screenshot - I put value-prefix-W-1- into cell B4, which seems to have the existing filtering info in for the ID prefix. It tells me there are 14 Objects that meet this criteria, but when I hit the tick button the formula "(('Window'.'IDPrefix'='W-1-'))=(Window.IDLabel)" is repeated into every box in the C column, instead of operating as a filter. I'm sure I'm missing something simple, but I'm afraid its not obvious to a beginner! Quote Link to comment
JMR Posted February 26, 2018 Share Posted February 26, 2018 Ok, now I get it: You need to define the main criteria in the header row, please see screenshot: Right click on the header row (number 2 in my screenshot), thus you get to enter the search criteria. Limiting the schedule to 1st floor windows goes like this: layer - is - yourfirstfloorname, and so on. Field values are handy but if you can use only layers as criteria, all the better. Quote Link to comment
mike-h Posted February 26, 2018 Author Share Posted February 26, 2018 I think I'm getting there - Forum to the rescue once again, thankyou. Quote Link to comment
RickR Posted February 26, 2018 Share Posted February 26, 2018 I've found worksheets can do an amazing number of things. Getting to know all their options and methods will pay of in a big way. Quote Link to comment
Randy Y Posted July 14, 2018 Share Posted July 14, 2018 Does someone have an example of a successful implementation of keynotes? I’m trying to place keynote #1 for example, several times; then if I need to change the callout to #5, I cannot easily do this. Am I missing something? Quote Link to comment
RickR Posted July 14, 2018 Share Posted July 14, 2018 I regularly use key notes. Sometime more than one set on a sheet. To manage them I find it easiest to use the database part of the notes tool. Select a note and "update" it from the database. That makes sure the various versions are exactly the same text. I'm also known to just copy existing notes. But practically speaking just editing a note instance should change it. This file is a mini example. If it doesn't help maybe you can explain your issue in more detail. Keynotes.vwx Quote Link to comment
