klaus Posted July 22, 2004 Share Posted July 22, 2004 Hi Is there any way I can toggle in VW 10 between the offset modes in the double line polygon tool using the command key (apple key) as could be done in VW 8 this is very usefull if you haven't set the correct offset mode when you start drawing a double line poly Also when I am using a tool in VW 10 and press the x key as a shortcut to the 2D selection tool, when I press x again after using the selection tool it no longer returns to the previous tool as it did ion VW 8 again very usefull for lazy me can someone let me know how to get these features to work in VW 10 Quote Link to comment
Guest Posted July 22, 2004 Share Posted July 22, 2004 Use the U key to toggle through the first set of any mode buttons, i for the second set, o for the third, p for the fourth, and [ ] for the fifth and sixth. xx deselects everything in the drawing and leaves the 2d selection tool selected. There is a boomerang mode - hold down the space bar while using another tool. When the space bar is released, you'll be back at the previous tool. I just went back to VW 8 and keyed x twice and it works the same as it does in VW 11. Did I miss something? [ 07-22-2004, 11:50 AM: Message edited by: Katie ] Quote Link to comment
klaus Posted July 23, 2004 Author Share Posted July 23, 2004 Hi Katie thanks for that ... the thing with the x key only seems to work in VW 8.5.1 ..... I just tried it in VW 8.5.2 and it does not work I used to use 8.5.1 a lot more than 8.5.2 because it didn't mess up text in pdf documents but now it seems it also does not use x to return to the previous tool have a go in 8.5.1 ..... draw a line, press x, move the line, press x again and it goes back to the line tool (or any tool you were using for that matter) .... I used to use the feature a lot where I needed to rotate lots of drawing elements or select things fo clipping etc nice feature, why not put it in the next update Quote Link to comment
