Martin Crawford Posted February 14, 2018 Share Posted February 14, 2018 In the attached file one of the Sequence Node is creating 2x the amount of data that it should. If I enter a 5, I get 10 items in the list. Can you someone check and see if the issue is unique to my computer or a problem with the specific node. I was able to delete the node, add it back and get things to work correcly. However, I am now nervous on how a node could not work correctly. This makes me concerned about the stability and viability of Marionette for production critical use. How can I tell why it's not working? Thanks Martin Sequence_Node.vwx Quote Link to comment
Vectorworks, Inc Employee SBarrettWalker Posted February 14, 2018 Vectorworks, Inc Employee Share Posted February 14, 2018 Hi Martin, I looked at your file, and it is actually a weird glitch that I have seen happen once or twice. Somehow, your H pass node is connected to the sequence node twice. This shouldn't be possible - it is definitely a bug, but if you disconnect the H pass node completely and reconnect it, it should work properly. HTH, Sarah Quote Link to comment
Marionette Maven Marissa Farrell Posted February 14, 2018 Marionette Maven Share Posted February 14, 2018 It looks like somehow you have two wires coming out of H into your sequence node. Was this file created in SP2? did you copy paste the top part to get the lower part? Any information on how this network was created would be helpful. It's not anything I've run into personally. Quote Link to comment
