Mikedk64 Posted February 14, 2018 Share Posted February 14, 2018 Hi, I have this floor made of following layers, Sand, concrete and tiles. The two first layers is just flat and wall to wall. But the tile layer has to have a virtical edge. In my test file, did I use the slab tool with the three layers, and afterwards did I make a 3D object, added that to the slab and so on. My problem is, that the top layer (tile layer) dosent follow the wall anymore. So is there a way to make the little edge, and still keep the auto-bound to the the wall? I do also need to have a drain in the floor (like in the file) I have attached a file, with my example. Test.vwx Quote Link to comment
Matt Overton Posted February 14, 2018 Share Posted February 14, 2018 Not that I've found, so really just tagging myself in case someone has. It would be useful. Quote Link to comment
