Project Sharing Title Block
Gaspar Potocnik
I'm using project sharing and in my title block using Project Data.File Name . The file name being used is my working file and not the "mother file". Is this the way it should be? If it is OK then it means that which ever user publishes the sheet layers, it will use that file name.
I guess the only workaround is to use a custom record and manually enter the name of the project file.
Cheers
1 answer to this question
