Generate Wall Styles from spreadsheet
Sbd
Is it possible to create a plugin or marionette that reads a worksheet or spreadsheet and uses that information to generate wall styles? The reason for this is because in todays world - the amount of wall types, STC ratings, UL ratings, and R ratings of wall styles is dramatically increasing. In order to minimize the production time for generating wall styles for a firm, what if they were able to be generated from a spreadsheet?
Using the same information that you would receiving information from a schedule, instead you generate the wallstyles by imputing the information into a table using the same record labels for the parameters that set the thickness of components, description of components, and description of the wall style, UL and STC ratings / R & U values.
