PeterT Posted July 15, 2004 Share Posted July 15, 2004 In VW version 10.5, if you offset the same line multiple times rapidly, nothing offsets on the second mouse click. If you offset slowly though, it works fine. Has this been fixed in version 11? It is a bit frustrating. Thanks, Peter Quote Link to comment
jan15 Posted July 15, 2004 Share Posted July 15, 2004 Interesting. I get that, too, in 10.5.1 on a PC. I never noticed it before, but then I rarely use v10. It doesn't have to be very fast multiple clicking to make it happen, either. Quote Link to comment
PeterT Posted July 16, 2004 Author Share Posted July 16, 2004 Katie, I am on Mac OS 10.3.4 and running VW 10.5.1. I also just tried it on VW 9.5.3 and I get the same bug there. Going back to version 8.5.2 in Classic, it works normal again. To replicate it just draw a line, get the offset tool, choose offset by distance, and click twice rapidly on one side of the line. When I do this, I only get one copy, not two. But if I click three times rapidly, I get two copies. It is only the second click that is failing. Quote Link to comment
matto Posted July 16, 2004 Share Posted July 16, 2004 I think you will find that if you move the mouse away from the line as you click it keeps working. It's not really a bug per say. It's a setting that applies to most tools that treat any click until the mouse has moved a number of pixels as a second click. (it's documented in the SDK). Which is a great thing for Polylgon tool. But to answer your question. Yes it has been fixed in VW11. Quote Link to comment
Guest Posted July 16, 2004 Share Posted July 16, 2004 Iboymatt is correct. If you double click in place, only one object is created. If you click two times but move the mouse while clicking the two times, two lines are created. It's the intended behavior. Quote Link to comment
jan15 Posted July 18, 2004 Share Posted July 18, 2004 But that rule about moving the mouse before clicking again doesn't apply to any except the second offset. You can click 3 times without moving the mouse and you'll get 2 offsets, or 4 times without moving the mouse and get 3 offsets, 15 times and get 14 offsets, etc. It's a bug. Quote Link to comment
Donald Wardlaw Posted July 19, 2004 Share Posted July 19, 2004 In my opinion if this behavior is by design, it could be better. Why require the mouse to move? Does that serve some important purpose? It can be faster not to move the mouse---to hold the mouse far enough away from the source object so that all duplicates will end up between a fixed mouse position and the source object. So if you want 11 new objects, you count off 11. Best, Donald Quote Link to comment
PeterT Posted July 20, 2004 Author Share Posted July 20, 2004 As far as I know, the only prerequsite of offset by distance is the distance itself, and the direction of the offset. Both of these are set before the first click. After this, all that is needed is the number of clicks, i.e. the number of copies. The tool should have nothing to do with how fast you click, or weather the mouse moves or not. Why would it possibly be intended that this tool require the mouse to move after the first click? Oh well, according to iboymatt, VW11 has resolved this issue anyway. Quote Link to comment
jan15 Posted July 21, 2004 Share Posted July 21, 2004 It's just a bug. Which noone noticed until much later. Version 8 doesn't have the problem. It will offset as many times as you want and as fast as you want without moving the mouse. Quote Link to comment
