SCParker
Recalculate worksheet command without clicking on worksheet?
Hi All,
Is there a way to recalculate worksheets without actually having to select a worksheet and right-click to choose recalculate? I've searched for the command in the workspace editor with no luck.
Thanks, Scott
Share this post
Link to post
1 answer to this question
As far as I know there's no built in command. You can write a script to do it though. I've got one to recalculate all worksheets in a file, but you could modify it to do just one specific instance by name. Vectorscript below. I set it up as a Plugin so I could make it a custom menu item. I borrowed and adapted this from someone else's work, so it's possible it could be simplified. Hope this helps.
-Dan
{Recalculate all worksheets in file}
Procedure WSrecalc;
VAR
foundObject: handle;
objname :String;
i, n : integer;
OK : boolean;
function DoRecalc (h : handle) : Boolean;
BEGIN
	RECALCULATEWS(h);
	RESETOBJECT(h);
	RESETOBJECT(GETWSIMAGE(h));
End;
Begin
n := NAMENUM;
	For i := 1 to n do begin
		foundObject := GETOBJECT(NAMELIST(I));
		If GETTYPE(foundObject) = 18 Then ok := DoRecalc(foundObject);
	End;
End;
Run (WSrecalc);
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
